Boost not holding for some reason?
Old Sep 25, 2005 | 10:27 AM
turbotime's Avatar
Default Boost not holding for some reason?
Hey i just got my turbo setup runnin nice, and we were around gettin on it to make sure nothin was wrong, and it was runnin fine boosting 9psi.
Then we get home and i notice the boost gets to like 5psi and then drops to 0 like its losing boost or something.
SO i think its either a loose charge pipe or possibly a vaccum leak?
what do you think?
Old Sep 25, 2005 | 10:30 AM
hotimportcrx's Avatar
Default Re: Boost not holding for some reason? (turbotime)
or your wastegate could be messed up
Old Sep 25, 2005 | 10:33 AM
turbotime's Avatar
well its been working fine so far so i doubt its the gate- its a 38mm and they dont just break like that right?
i mean its only 9psi
Old Sep 25, 2005 | 11:45 AM
turbotime's Avatar
top
Old Sep 25, 2005 | 01:28 PM
notanotherSC61's Avatar
Default Re: (turbotime)
You need to pressurize the system with an air compressor and check for any hissing. This is a very low boost pressure to loose so much, it has to be a large hole or maybe your bov is staying open when it should be closed?
Old Sep 25, 2005 | 07:59 PM
turbotime's Avatar
bump for more info!
~ so your saying you think its a vacuum leak? It didnt feel like it was losing boost, just the gauge was showing it losing boost.
Old Sep 25, 2005 | 08:26 PM
I'm saying it may possible be a vacum leak but to loose that much would have to be a LARGE hole. Are you running a boost controller or just a spring? Also was it running at 9 then dropping to 5 then 0 or, it wont make up to 9 anymore? Also if you are running a cheap gauge it may just be sloppy. MAybe the line got pinched going to the gauge.
Old Sep 25, 2005 | 08:57 PM
turbotime's Avatar
yeah it is a pretty cheapo guage- ebay "SPW" 7 color. it was cheap.
i am running off the gate and spring, no controller yet.
I was saying it was running fine at 9psi, then for some reason or other it just started going to 5 then dropping to 0.
wheres before it would go to 9 then negative when i shift and such, like its supposed to.
Old Sep 26, 2005 | 06:22 AM
turbotime's Avatar
think maybe my BOV is loose? I have a hks SSQ and didint think to check if the bolt on it was tightened down, maybe cause its a lil loose its losing boost?
ragethemachine86
Sep 12, 2006 07:58 PM
0618turbocivic
Jul 16, 2006 03:46 PM
dan_w_82
Mar 28, 2006 11:37 AM
nzrnk
Apr 5, 2005 04:40 AM
93TurboSi
Oct 16, 2003 06:04 PM
