boost leak question, this time I cant find it.
Old Jul 22, 2004 | 08:41 PM
Sinner's Avatar
Default boost leak question, this time I cant find it.
I'm working on finding a boost leak. I hooked up electric air pump to my charge pipes and it sits at 7psi. 7psi is where my boost controller is set to. When I drive, I will hit 7psi quickly then drop to 5psi. I assume this is a major boost leak since it used to not do this. I have had plenty boost leaks in the past but soapy water + the air pump would always find them. Anyone have any ideas?
Nick
Old Jul 22, 2004 | 11:04 PM
Ceres's Avatar
Wastegate...Vacuum connections?
Old Jul 22, 2004 | 11:14 PM
Sinner's Avatar
yea I checked and even zip tied them, I actually improved the vaccume at idle. I disconnected the host going to the wastegate for one test, so its not the wastgate.
Old Jul 23, 2004 | 12:44 AM
Calvinator's Avatar
sometimes the leak in the charge piping is not visible by eye. Try feeling around your piping.
Old Jul 23, 2004 | 12:57 AM
honda9369's Avatar
Default Re: boost leak question, this time I cant find it. (Sinner)
DFB
Old Jul 23, 2004 | 01:01 AM
honda9369's Avatar
Old Jul 23, 2004 | 01:30 AM
Sinner's Avatar
Default Re: (xtremeazian)
yep, I think I found it. I felt the air like you said, but it just doesnt seem like enough to matter. I'll will fix it tomorrow.
Nick
Old Jul 24, 2004 | 04:41 PM
Ceres's Avatar
Well Its most likely a leak not any parts malfunctioning. As you said before it gets boost but it drops, so check all connections and make sure that none of the charge piping is not leaking or cracked. Let us know what happened and how you fixed it.
Old Jul 24, 2004 | 06:54 PM
Bailhatch's Avatar
Default Re: (Ceres)
Another thing to check is your air filter if the boost builds up and then drops but used to be stable. Just happened to me. now i run no filter. aren't I cool?
Old Jul 30, 2004 | 03:16 AM
Sinner's Avatar
Default Re: (Bailhatch)
I think I'm going to check that, it sucks having 6 psi...
Nick
turbo-crx
Jan 24, 2009 09:06 AM
ragethemachine86
Sep 12, 2006 07:58 PM
crispydee
Oct 17, 2004 10:47 AM
turbo se
Jun 24, 2003 08:12 AM
1.8EG-T
Jan 24, 2002 12:36 PM
