Boost By Gear Question
Old Jun 18, 2016 | 07:49 PM
  #26
2kdrift's Avatar
Default Re: Boost By Gear Question
Originally Posted by Turbo-LS
I use the quick spool on my street car. When I was running s300 in my drag car I manipulated boost with tables only.
I see thanks for the input, been using the table method on my street car havent played with the quick spool function yet
Old Jun 18, 2016 | 10:01 PM
  #27
LightningTeg's Avatar
Community Builder
Xenocron has some good write ups
http://www.xenocron.com/install/PWM-...00-neptune.htm
Old Jun 18, 2016 | 10:22 PM
  #28
boosted94gsr's Avatar
Neptune has gear vs rpm wg duty cycle. I set mine up like this on my last hatch. I had it hold 100% dc while it spooled up, it made a noticeable difference. Worked really well.
Old Jun 18, 2016 | 10:36 PM
  #29
2kdrift's Avatar
Hondata has the same thats how ive been doing it. 100% lol thats intense I usually go 75% at the most
what frequency is that?
Old Jun 18, 2016 | 10:42 PM
  #30
I don't remember of the top of my head. I'd have to open the calibration, but I think it was set to 31. It's just a standard $30 mac valve.
Old Jun 18, 2016 | 10:47 PM
  #31
2kdrift's Avatar
Yea I keep forgetting Im using the 4 port and most others use the 3 port
Old Jun 19, 2016 | 03:56 AM
  #32
ls joker's Avatar
Loved
So im gona guess the quick spool setuo is way more effective than a mbc. Due to the fact of being able to hold the wastegate completely closed. I didnt think MBCs held wastegate closed that much.
Lightning teg, thanks for the write up
So is the four port more responsive or what. Looks like xenocron has two different four ports, and a three port.
Old Jun 19, 2016 | 05:22 PM
  #33
2kdrift's Avatar
the four port is used to have a wider range of boost control, 3 ports were good for 2-3x your spring pressure whereas a 4 port is good for 4x or more
the 4 port has the ability so route pressure above the wastegate spring as well as below it, which my wastegate supports and seems like an advantage
Im getting about 4x out of mine havent needed any more then that just yet.
call up b&r fittings he was working on getting a newer mac valve I beleive its more responsive that was earlier this year he should have them now
Old Jun 19, 2016 | 05:41 PM
  #34
TheShodan's Avatar
Moderator
Ah, how the world turns. My partner and I developed those for B&R. It's an OEM based solenoid with some voltage adjustments . they've been out about a year.
But you might not like them, as technically they would be considered a "3 port".
Old Jun 19, 2016 | 05:48 PM
  #35
2kdrift's Avatar
nah you must be thinking of something else, this one comes in 3port or 4 port variation, not oem either its a mac valve
Old Jun 19, 2016 | 05:52 PM
  #36
TheShodan's Avatar
Moderator
If you say so.
Old Jun 20, 2016 | 03:39 PM
  #37
ls joker's Avatar
Loved
Im leaning on the xenocron 4 port, pwm kit, and capacitors
ringgold
May 11, 2004 09:38 PM
eghatchproject
Feb 21, 2004 04:57 PM
djnikko
Aug 14, 2003 03:55 AM
ludelvr
Jun 24, 2002 12:31 AM
DamonBoost
Nov 22, 2001 01:14 PM
