Boost cutting HELP?!
Old Aug 13, 2010 | 10:01 PM
crx33's Avatar
Default Boost cutting HELP?!
I have a ls swapped crx si...... built for boost.... Recently while i was over at my tuners house we were trying to get the numbers right (Can't even get boost readings) as we drive and start to get into about 4lbs the car starts to shake and cut out..... we get some of the base map cleaned up and finally start to hit about 10-12lbs feeling pretty strong but still cutting out.... cant figure it out? We get back to the shop plug into the ecu and setting in N we begin to slowly rev the motor to see what's going on.... at about 1500-1700rpms the car starts surging? I got so pissed of messing with it i finally plug all my oil lines undid the intercooler and put my ls back stock until i could get some advice.... i've done some reading but cant find anyone that has had this type of problem? SOMEONE HELP ME OUT I WANT BOOST!!!! let me know if you need details about the motor intake setup anything..... not sure where else to go????
Old Aug 13, 2010 | 11:59 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Boost cutting HELP?!
you have no info on setup.
ems? map sensor?
if were to guess, stock map sensor? it is hard to have a low enough boost cut with a stock map sensor.
Old Aug 14, 2010 | 12:34 AM
Gold DA9's Avatar
what he said...
also what is your spark plug gap?
Old Aug 14, 2010 | 07:44 AM
crx33's Avatar
map is the gm 3 bar....... NGK's gapped at 24-25 set up is b18a1 cp pistons golden eagle rods..... ac cam gears skunk2 intake t3t4 turbo all hooked up to the hondata s300
Old Aug 14, 2010 | 12:06 PM
crx33's Avatar
BUMP people come on help me get boosted!
Old Aug 14, 2010 | 01:00 PM
Mr. Badwrench
are you getting a cel when this happens? you have s300 are you logging while this is happening and going back to see if anything is irregular?
we can only throw darts sorry. there isnt too much to go on.
Old Aug 14, 2010 | 07:09 PM
crx33's Avatar
right now we've pretty much got it narrowed down to either the aicv tps or had a bad dizzy..... one guy told me the charge piping was to small.... i since put 3" on and still same problem..... the s300 shows nothing out of place.... just at 1500-1700 rpms it surges....
crx33's Avatar
no cel is on during any of this....
Hiboost 2.0
Apr 17, 2013 08:14 PM
crx33
Aug 14, 2010 07:06 PM
crx33
19
Aug 14, 2010 07:17 AM
the.hamburglar
Aug 2, 2007 02:44 PM
keith98
Jun 11, 2006 11:21 AM
