please expert help turbo problem
Old Aug 13, 2010 | 03:50 PM
4drteg54321's Avatar
Default please expert help turbo problem
Sup, honda tech am having a tuurbo problem I can't solve. It a stock evo 3 turbo that has been rebuilt and been working fine for over a month. My turbo would spool but no boost and the spool noise has gotten quiter use to be real noticable, I can still hear just not as much. I have check everything at least ten time. I did a boost leask test, check the wastegate, open the turbo and everything seem to be in working order I have no loose coupler. Am sure the main problem is the turbo I just don't no how to fix it, the turbo has zero shaft play and spins freely. The problem also occur 4month ago. I fix it back then but all I did was open it up and put it back togther and it worked didn't happen thiss time. Plzzz I need some help. Thanks.
Info on the motor
B16 turbo
Afc hack
Old Aug 13, 2010 | 06:55 PM
Default Re: please expert help turbo problem
Come on ht anything would help (drunk as hell right now)
Old Aug 14, 2010 | 04:45 AM
I've been searching for hours on the net no solution.
Old Aug 14, 2010 | 04:51 AM
90Rexx's Avatar
search for large boost leaks, remove your compressor and exhauts housing on the turbo and look for damage to the wheel
Old Aug 14, 2010 | 04:36 PM
I open the turbo about 4 time ill ready I check clean look for cracks I see nothing wrong with the turbo
Old Aug 14, 2010 | 04:41 PM
boostedeg302's Avatar
Sounds like a major boost leak to me. Either due to a charge pipe coming off or something of the sort. I know you already stated that you checked it all but how thoroughly? Sometimes they can come off without being visually noticeable. Grab each section of intercooler pipe and tug to see if it is loose. Also check your intercooler for any sort of holes or anything but this is uncommon.
Old Aug 14, 2010 | 09:46 PM
I did a boost leak test came out good. I also check everything clamps and hoses. I no the problem is the turbo I just don't no what. Remeber I tryed my friend 18g and it worked perfect.
Old Aug 14, 2010 | 11:38 PM
chewyv's Avatar
pm4nudes
Was rebuilt to different specs? rebuilt with crap parts causing a warped blade?
recovery69
Feb 3, 2009 10:04 PM
hoskos
Apr 23, 2007 06:12 AM
95whitegizzer
Jun 28, 2006 05:21 PM
b00stedbyFastrax
May 11, 2004 02:55 PM
