Boost Creep Killed LsVTEC T
Old Sep 24, 2006 | 05:43 PM
GaVO311's Avatar
Default Boost Creep Killed LsVTEC T
I just finished my car and the motor only had about 1500 miles on it without turbo the turbo was finished and on the test drive after the rechip blew the vacuum line off the wastegate to the turbo feeding the motor 28 pounds of unrighteous boost. Severe detonation My Pride and joy SHattered all four cylinder walls into rubble.
My Ls Vtec Turbo
<U>Head:</U>
fresh B16a
Rc 550cc
aem fpr
Walboro 255
<U>Block:</U>
B18a
rebuilt
micro polished crank
balanced rotating assembly
Arp Rod Bolts, Head Studs
King Rod and main Bearings
Type R Oil Pump
<U>Trans:</U>
B16 Honda LSD!!
<U>Turbo Setup:</U>
Turbonetics .54 trim ballbearing turbo
Turbonetics Deltagate 7psi Spring
Drag Gen 3 turbo manifold
Blitz Blow JOb Valve
Custom piping and intercooler
I Guess it happens to the best of us but its crazy how a little vaccum line caused that much damage.
I am looking for a Gsr or ITR Block complete or bare let me know it u have one for sale i need to get this thing going again. Thanks
Old Sep 24, 2006 | 05:47 PM
urbansi's Avatar
Default Re: Boost Creep Killed LsVTEC T (GaVO311)
That sucks buddy. Hopefully the dark side is strong in you for another build.
Any pictures of the carnage
Old Sep 24, 2006 | 05:48 PM
drintegra's Avatar
sorry to here that, keep your head up
Old Sep 24, 2006 | 05:55 PM
96 GSR-T's Avatar
Default Re: Boost Creep Killed LsVTEC T (drintegra)
How did the car feel running 28lb? Sucks man.....
Old Sep 24, 2006 | 05:58 PM
turbo boost's Avatar
Default Re: Boost Creep Killed LsVTEC T (96 GSR-T)
couldnt u have had the boost cut on and have prevented this??
Old Sep 24, 2006 | 06:11 PM
GaVO311's Avatar
Default Re: Boost Creep Killed LsVTEC T (snowbunny)
Thanks i hope to have it going again soon i will get some pics off they are pretty nasty i figure the block would make a lovely coffee table though i will now be tuning the car on crome instead of uberdata so i will be able to control my boost better because i dont think i had that option in uber. Also Clamp every vacuum line on the damn thing&gt;
Old Sep 24, 2006 | 06:23 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GaVO311 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks i hope to have it going again soon i will get some pics off they are pretty nasty i figure the block would make a lovely coffee table though i will now be tuning the car on crome instead of uberdata so i will be able to control my boost better because i dont think i had that option in uber. Also Clamp every vacuum line on the damn thing&gt;</TD></TR></TABLE>
uber does have a boost cut feature. Do you have stock map sensor still or aftermarket? Its not so good if you are running close to the max of the stock sensor, but if you have a map sensor that reads higher then its fine. It will basically give you a lower rev limit if you hit too much boost. Not quite as good as cromes because crome will cut fuel right when it sees too much boost, but still better than nothing.
Old Sep 24, 2006 | 06:24 PM
Silverbeast's Avatar
Push on nylon high heat hose and fittings... NEVER will come off.
I will vouch for them. PM me if you have any questions.
Old Sep 24, 2006 | 06:55 PM
blackeg's Avatar
Default Re: (Silverbeast)
you could have even just used a hose clamp or a zip tie, that will help do the job.
i feel your pain though, i had boost creep and maxxed my fuel system out. cracked my sleeve and trashed that motor. it sucks
edit::: i see you ran a deltagate....they have a reputation for creeping
Old Sep 26, 2006 | 03:02 PM
GaVO311's Avatar
Default Re: (blackeg)
new block is on the way im going with an itr block this time with block guard and cylinder enforcement pins lets hope these cylinder walls dont come tumblin down
Old Sep 26, 2006 | 03:52 PM
RedR's Avatar
Default Re: (GaVO311)
thats why i love my boost cut protection.
Good luck for the next build
Old Sep 26, 2006 | 07:15 PM
Turbo-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">you could have even just used a hose clamp or a zip tie, that will help do the job.
edit::: i see you ran a deltagate....they have a reputation for creeping</TD></TR></TABLE>
Agreed, i double zip tie ALL of my vacuum line son my engine and have never had an issue with them blowing off. i blew charge pipes off on the dyno though lol sounds liek a rod through the block at 25 psi LOL
Old Sep 26, 2006 | 08:51 PM
HamiltonRex's Avatar
Default Re: (Turbo-LS)
i use mini hose clamps on all my vac lines. The small ones for boost gage etc.. Get tie wraps.
Old Sep 26, 2006 | 08:54 PM
OBRJosh's Avatar
Default Re: (HamiltonRex)
28psi on a 7psi waste gate spring is more then Boost creep HAHA, more like max boost for the turbo
Old Sep 26, 2006 | 10:54 PM
SOHC_me's Avatar
Default Re: (OBRJosh)
does anybody know if hondata s200 has boost cut?
Old Sep 26, 2006 | 11:49 PM
SiKid86's Avatar
Default Re: (SOHC_me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_me &raquo;</TD></TR><TR><TD CLASS="quote">does anybody know if hondata s200 has boost cut?</TD></TR></TABLE> It better if your paying like 200-300 bux for it and the free programs have it
97boostedteggy
Apr 18, 2016 11:39 PM
Bonestock98GS
Sep 23, 2012 04:55 PM
gutti9
Nov 3, 2011 04:31 PM
phaphon
Jan 17, 2011 02:48 PM
tegman23
Sep 23, 2007 07:54 PM
