Which boost controller(s) allow gear-based boost level.
Old Jul 14, 2003 | 08:02 AM
vtec.dc2's Avatar
Default Which boost controller(s) allow gear-based boost level.
Is there such product?
Old Jul 14, 2003 | 08:07 AM
CheezeFrog's Avatar
Default Re: Which boost controller(s) allow gear-based boost level. (vtec.dc2)
I think I've read somewhere that the World Electronics boost controller allows for this. Don't quote me on that though
Old Jul 14, 2003 | 08:09 AM
Greyout's Avatar
Default Re: Which boost controller(s) allow gear-based boost level. (CheezeFrog)
I want to know how teh fawk it knows what gear you're in
Old Jul 14, 2003 | 08:17 AM
guido-kp's Avatar
i installed an apexi avc-r in an eclipse once, i didnt set it up for it, but it looked as it if had provisions for gear based boost. somehow it "learned" what gear the car was in.
Old Jul 14, 2003 | 08:27 AM
SEFIxCivic's Avatar
Default Re: Which boost controller(s) allow gear-based boost level. (Greyout)
based off the speed sensor.
i think the best boost control is a motec ecu. sure its expensive, but when you add up the price of your stand alone, then add a speed based boost control, and misc things, you'll see that you get your money's worth.
Old Jul 14, 2003 | 08:30 AM
drvfast's Avatar
apexi boost controller has one
Old Jul 14, 2003 | 08:36 AM
jinxproof99's Avatar
New User
Default Re: Which boost controller(s) allow gear-based boost level. (SEFI8LOxCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEFI8LOxCivic &raquo;</TD></TR><TR><TD CLASS="quote">based off the speed sensor.
i think the best boost control is a motec ecu. sure its expensive, but when you add up the price of your stand alone, then add a speed based boost control, and misc things, you'll see that you get your money's worth.</TD></TR></TABLE>
absolutely the best but extremely time consuming to set up correctly(traction control) and illegal in most sanctioned events.
Old Jul 14, 2003 | 08:42 AM
PM-Performance's Avatar
Default Re: Which boost controller(s) allow gear-based boost level. (jinxproof99)
Rado runs his in thr Celica and thye let him go with it . But yes the World E one has it , the Innovative has it and the AVCR has it
Old Jul 14, 2003 | 08:44 AM
SEFIxCivic's Avatar
i don't think its considered traction control. isn't the innovative boost controller and apex avcr based upon the same idea, limiting boost according to speed?
the motec traction control function compares the speed of the driven wheels vs the non driven wheels, and momentarily cuts ignition and/or fuel reducing engine power when a certain amount of slip is detected.
Old Jul 14, 2003 | 09:00 AM
New User
i believe the motec traction control feature is not allowed in nhra, nopi, idrc..........
i was told that the techs check the wheels and if there are any sensors visible whatsoever, you are dq'ed.
Old Jul 14, 2003 | 09:02 AM
CRXRageD's Avatar
The blitz sbc-id has one with the power meter hooked up. You program it based on speed. So 0-25mph no boost, 25-35mph 7psi, 35-60mph 13psi, 60-80mph 17psi,80+mph 25 psi, you get the idea...
Old Jul 14, 2003 | 09:17 AM
vtec.dc2's Avatar
i also found MSBC-1.. http://www.dragbike.com/news/10-00/103100a.htm - anyone using that?
Old Jul 14, 2003 | 09:21 AM
Charlie Moua's Avatar
Default Re: Which boost controller(s) allow gear-based boost level. (CRXRageD)
MORE info on this would be great...
I wonder if hondata is working on somthing like this...
Old Jul 14, 2003 | 09:37 AM
SEFIxCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jinxproof99 &raquo;</TD></TR><TR><TD CLASS="quote">i believe the motec traction control feature is not allowed in nhra, nopi, idrc..........
this is true. it's too bad that it isn't allowed, but i guess its understandable since it takes out the driver in the 1320 equation.
Old Jul 14, 2003 | 09:42 AM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">i also found MSBC-1.. http://www.dragbike.com/news/10-00/103100a.htm - anyone using that?</TD></TR></TABLE>
A friend of mine is using that on his GT80'ed camaro, i'll talk to him about it and see how you go about setting it to vary boost depending on gear or whatnot.
calib17a
Jul 7, 2008 12:13 AM
boosted_ejcivic
Mar 28, 2007 03:11 AM
JrCRXHF
Nov 13, 2003 03:50 AM
Kack
Aug 25, 2003 11:25 PM
