BLITZ DUAL SBC-ID boost controller & PWR METER ID
i did a search and i could not find **** about anyone that used them on a honda. how well does it work to keep the boost low untill you can get traction say if i wanted only 6psi (which my spring is) in frist gear and then untill i hit 6000rpm in second then up the boost to say 7psi and so on. is this posiable if so how hard?
Re: BLITZ DUAL SBC-ID boost controller & PWR METER ID (JrCRXHF)
anyone have a idea someone has had to run this setup before what is everyone doing for a boost controler
Re: BLITZ DUAL SBC-ID boost controller & PWR METER ID (RH+G)
It looks like he's talking about gear and rpm dependent boost control, which the sbcid does not deal with. Like mentioned above, boost scramble is what you would have to use...and it is dependent upon throttle position
Re: BLITZ DUAL SBC-ID boost controller & PWR METER ID (PureTeg420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PureTeg420 »</TD></TR><TR><TD CLASS="quote">It looks like he's talking about gear and rpm dependent boost control, which the sbcid does not deal with. </TD></TR></TABLE>
WRONG ... if you get the power meter you do indeed have speed sensitve/gear dependent b00st. the two devices communicate with each other via the infrared port and blam, there you go...
they will both be installed on my pig in a couple of weeks, i'll let you know how it goes
I was thinking of using it a while back - but I think I will be using a Saab APC instead, with a little modifications it will do wonders
Cannot help with the gear based control, but I have been using the SBC-id II for a while. It has performed excellent, I have never had any spiking....ever. I am using it with a (cough) Deltagate, and it holds to exactly what I set it to.
