boost controller install, quick question.
Old Apr 25, 2008 | 11:22 PM
HamiltonRex's Avatar
Default boost controller install, quick question.
Hi. Using a Tial 44mm WG, with a AVCR.
The 2 vac ports on the tial, the one on the side gets connected to vac, and the one on the top goes to the [com] port on the solenoid, and the [no] on the solenoid goes to vac source.
Sound right?
Old Apr 25, 2008 | 11:24 PM
Default Re: boost controller install, quick question. (HamiltonRex)
oh yes.. for the vac source for the solenoid and wastegate, i am using the compressor housing.
Thanks.
Old Apr 26, 2008 | 05:45 AM
dpetro1's Avatar
link to manual http://www.apexi-usa.com/pdfInstallation/45.pdf see page 47 of the pdf for external wg install
1. side port of wg to compressor hosuing
2. top port of wg to COM
3. tee into line #1 and run to NC
so basically the side port of wg and NC port of avc-r need to go to the comp housing. NO port is NOT used in our appliction. i believe its more for factory turbo vehicles.
Old Apr 26, 2008 | 10:52 PM
Default Re: boost controller install, quick question. (dpetro1)
ok.. so on the solenoid valve i have to use NC
crx1856
Aug 31, 2013 12:33 PM
TunerShark
Dec 27, 2006 06:00 PM
UtahRockabilly
Mar 13, 2003 02:47 PM
blu_si
Dec 10, 2002 09:36 PM
boosted hybrid
Mar 1, 2002 05:44 AM
