which boost controller
Old Aug 31, 2011 | 05:56 AM
dropped93ex's Avatar
Default which boost controller
What boost controller should i get for turbo b18c1 in an eg
Old Aug 31, 2011 | 06:28 AM
ashb82's Avatar
Default Re: which boost controller
pwm by far the best and cheapest on the market.
Old Aug 31, 2011 | 06:36 AM
TheShodan's Avatar
Moderator
Greddy Profec B. hahahahaah. Now quick, someone else throw a name out there without giving any explanation or asking what this person's setup or use is... c'mon.. quick, quick, quick. ;-)
Old Aug 31, 2011 | 07:19 AM
Stock gsr with 57trim looking to only run 8-10PSI of boost
Old Aug 31, 2011 | 08:22 AM
TheShodan's Avatar
Moderator
No boost controller at all then. Use a the correct spring on the wastegate and you'll be fine.
Old Aug 31, 2011 | 08:44 AM
sanman000719's Avatar
exactly
so when you go this route just so the op knows do you just run vac tubing from turbo to gate????
chrisgottigsr
Dec 15, 2005 05:49 PM
Sketch_hs
Jun 30, 2005 12:55 PM
1tyme
Nov 27, 2002 05:32 PM
simike
May 10, 2002 03:01 PM
Snafu-Si
Mar 5, 2002 02:07 AM
