boost controler question need help
Old Sep 3, 2005 | 04:36 PM
seros's Avatar
Default boost controler question need help
hi guys
i have a turbosmart dual stage boost controler (part number FG-GBCV-DS i think)i have a garett t3/t4 with an inlinepro manifold
this is what its supposta look like.
but my turbo dosne thvae that fitting called presure source so im stuck..... plzzz help
Old Sep 3, 2005 | 05:04 PM
urbansi's Avatar
Default Re: boost controler question need help (000s)
if your turbo has an external wastegate you shouldn't have to worry about it. correct me if i am wrong
Old Sep 3, 2005 | 05:13 PM
SiEcO187's Avatar
Default Re: boost controler question need help (urbansi)
The pressure source on the turbo isnt the only pressure source you can use. You can tee into a line that is leading directly off the intake manifold aswell. Do NOT use the line coming from the map sensor though, it has been know to be inaccurate. I belive you can tee into the pvc hose, someone correct me if im wrong. The point is though you can use any pressure source avaliable on your engine but its best to get it as close to the intake manfiold as possible.
Old Sep 3, 2005 | 05:24 PM
nota-eg's Avatar
Default Re: boost controler question need help (SiEcO187)
So you don't have a vacuum souce coming from your turbo? Like SiEcO187 said, you can use the vacuum souce between your intake manifold and your fuel rail. If you are using that for your BOV and boost guage it may be too weak.
Depending on what car you have, you may have to tap into your brake master cylinder. (D16Z6s don't have a 2nd vac souce coming from the manifold)
First I would use the manifold/fuel rail VAC source and T into that for your boost controler. If it's too weak I would get one of the T kits that allow you to use your brake master cylinder. I know GE makes a manifold kit.
Can someone provide a 2nd VAC source other than the brake master cylinder for Z6 motors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">if your turbo has an external wastegate you shouldn't have to worry about it. correct me if i am wrong </TD></TR></TABLE>
I think that even if he is using an external wastegate he will need a vacuum source so the WG knows when to open/close.
Old Sep 3, 2005 | 08:11 PM
seros's Avatar
Default Re: boost controler question need help (nota-eg)
thanks for the help ...
yeah i was thinking bout a a vacumm line from the maifold ot split a line between my guage and controler? but like nota-eg said i dont want a week reading
the motor is a obd1 gsr with a skunk2 mani
Old Sep 3, 2005 | 10:58 PM
JDM_EH2's Avatar
Just get a GE vaccum manifold...it makes things much easier...and looks better after the install. It's only like 30 bucks...basically you tee it off of ur brake booster and then u have a vaccum source for up to 6 things (BOV, WG, FPR, Boost Cont., Map sensor, etc...)
Old Sep 4, 2005 | 05:36 AM
seros's Avatar
Default Re: boost controler question need help (JDM_EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Just get a GE vaccum manifold...it makes things much easier...and looks better after the install. It's only like 30 bucks...basically you tee it off of ur brake booster and then u have a vaccum source for up to 6 things (BOV, WG, FPR, Boost Cont., Map sensor, etc...) </TD></TR></TABLE>
i want one where can i get one?
Old Sep 4, 2005 | 02:01 PM
JDM_EH2's Avatar
http://www.robearracing.com/pd...m.cfm
Thats where I got mine...came really quick too. Robear gets a from me!
99ek4Dr
Mar 6, 2013 07:14 PM
CaptainMorgan
Dec 5, 2003 12:53 AM
ProjectLudeSiR
Nov 19, 2003 08:27 PM
InTeGrA B18b1
Jun 21, 2003 02:34 PM
c-notecoupe
Dec 23, 2001 12:28 PM
