special or home depot will do?
Old Feb 28, 2006 | 07:11 PM
mrrugsr's Avatar
Default special or home depot will do?
special or home depot will do? thats the question! i have the turbo bolted to the manifold using regular home depot bolts. then it hit me. these suckers are gonna get hot! REAL HOT!> and im worried that the bolts could melt or something else worse? i also need to bolt the exhaust flange up to the turbo? can i use home depot bolts or must i find high temp bolts? thanks
Old Feb 28, 2006 | 07:23 PM
Boilermaker1's Avatar
Steel melts at over 2000 deg. I think you should be fine with HD bolts. Just make sure you use lock washers and or locknuts that DON'T have nylon lock rings in them.
Old Feb 28, 2006 | 07:58 PM
Outkast95LS's Avatar
Default Re: (Boilermaker1)
My friend is using regular OSH hardware on his wastegate. He said he doesnt have any problems. As am I, im also using some OSH bolts to hold up my wastegate, and so far nothing.
Old Feb 28, 2006 | 11:12 PM
raceACCORDingly's Avatar
i read some where that they should be 8.8 or 12.9 grade steel.
i got some 8.8 grade bolts at home depot, they are in the sliding droors sold in little baggies and have 8.8 stamped on top the bolt.
make sure you get some locking washers along with them, vibration will shake them loose.
Old Feb 28, 2006 | 11:17 PM
Default Re: (raceACCORDingly)
Oh yea, i forgot to mention, my bolts were 12.9 grade steel. So like raceACCORDingly said, make sure they are either grade 8.8 or 12.9.
Old Mar 1, 2006 | 11:29 AM
mrrugsr's Avatar
found some 8.8 bolts at a hardware store. they said there is no such thing as 12.9.......WHO KNOWS. would you guys put some never seize on them too
Old Mar 1, 2006 | 06:22 PM
Civicman86's Avatar
Default Re: (mrrugsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrrugsr &raquo;</TD></TR><TR><TD CLASS="quote">found some 8.8 bolts at a hardware store. they said there is no such thing as 12.9.......WHO KNOWS. would you guys put some never seize on them too</TD></TR></TABLE>
I dont think the never seize would stand up to the temps. Plus I have never had a problem with them seizing. IF anything people have a problem keeping the nuts on, cuase the vibration make them loosen.
Old Mar 1, 2006 | 07:55 PM
mrrugsr's Avatar
lock washers should keep them in though right?
20CiviC02Si
Mar 30, 2015 08:03 PM
mrrugsr
Mar 1, 2006 08:00 AM
greenGS
Dec 20, 2004 09:10 AM
swlabhot
Apr 29, 2003 08:19 AM
hybrid901
Jun 7, 2002 03:09 PM
