Blown motor, my choises
Old Aug 1, 2007 | 09:58 AM
ABK's Avatar
ABK
Default Blown motor, my choises
My buddy blew his b18c1. Only running 6psi with a hondata tune. I didn't take the head off but it seems like there is a big *** hole in one of the pistons. Pumping alot of pressure into the crankcase (causing the oil to burn from combustion going thru). Does not sound like ringslands because when that happens it sounds really bad. Either way if it a hole in the piston, I was thinking about just slapping some forged pistons and rods in there, but I'm not sure if they will be clearanced in there right and if I can get the rings to sit without honning the block (I really don't feel like taking the crank out).
He also has a built (the right way) allmotor LS-Vtec just sitting there 81.5mm. I was thinking about just taking rods and pistons out of that and slapping some forged pieces in there and putting that in the car.
Or just buying LS or B20 and putting that in the car.
I was wondering can someone give me some pointers on rebuilding the engine that's in there, or should I just do something else.
Old Aug 1, 2007 | 11:18 AM
morgan@synapse motorsport's Avatar
i would take the head off the car and go from there. the block thats in there might still be usable
Old Aug 1, 2007 | 12:07 PM
hondaluver's Avatar
k
Old Aug 2, 2007 | 08:48 AM
ABK's Avatar
ABK
Default Re: (hondaluver)
well if the block is good, can I put new pistons in there and rods without honning the block. Last time I took the head off like a month ago crosshatch was still there.
Old Aug 2, 2007 | 12:07 PM
ABK's Avatar
ABK
Default Re: (ABK)
ait ripped the head off. Found a cracked ring land on #4 piston. Need to bore and hone the block either way, the block is scored up.
Old Aug 2, 2007 | 12:38 PM
Default Re: (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">ait ripped the head off. Found a cracked ring land on #4 piston. Need to bore and hone the block either way, the block is scored up.</TD></TR></TABLE>
well thats not so bad, set of forged pistons and rods and that motor will be strong enough to handle some good power.
Old Aug 2, 2007 | 03:28 PM
turbolude1's Avatar
yup
Old Aug 3, 2007 | 08:29 AM
ABK's Avatar
ABK
Default Re: (turbolude1)
will have to take the block out of the car, take it apart and take it to the machine shop
Old Aug 3, 2007 | 09:03 AM
Default Re: (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">will have to take the block out of the car, take it apart and take it to the machine shop</TD></TR></TABLE>
yeah have them check it over, and go 81.5mm on the bore.
amalby
Aug 29, 2009 05:35 PM
97accord_R
Mar 23, 2009 02:29 PM
hondadriver
Sep 30, 2006 02:58 AM
del_slow420
Jul 27, 2006 08:58 AM
the.hamburglar
Sep 30, 2005 07:07 AM
