Blown Leitner & Bush block - pics inside
Old Jul 1, 2003 | 07:04 AM
Turboteggy's Avatar
Default Blown Leitner & Bush block - pics inside
Here's some pics of my blown Leitner&Bush block.
Melted J.E. piston #3:
Modified by Turboteggy at 11:10 AM 8/7/2003
Old Jul 1, 2003 | 07:39 AM
lazerus's Avatar
Default Re: Blown Leitner & Bush block - pics inside (Turboteggy)
Ouch. how did you blow it?
Old Jul 1, 2003 | 07:43 AM
Turboteggy's Avatar
I had a Cascar engine builder at my shop. He said the white ring around the piston is caused by blown rings. The motor was sucking oil&air past the rings and into the combustion chamber, leaning out the mixture. Never enough to blow up immediately, but slowly eating away at the edge of the piston, until finally it melted. That motor had about 40K of 17+ PSI on it. (2.5 years)
Old Jul 1, 2003 | 07:46 AM
SiBirdie's Avatar
Default Re: (Turboteggy)
how did the oil and air go pass your piston rings? what kind of block are you using..
Old Jul 1, 2003 | 08:14 AM
VaporTrail's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboteggy &raquo;</TD></TR><TR><TD CLASS="quote">I had a Cascar engine builder at my shop. He said the white ring around the piston is caused by blown rings. The motor was sucking oil&air past the rings and into the combustion chamber, leaning out the mixture. Never enough to blow up immediately, but slowly eating away at the edge of the piston, until finally it melted. That motor had about 40K of 17+ PSI on it. (2.5 years)</TD></TR></TABLE>
if air was going by the rings, that would mean less air in the chamber thus a richer mixture, not leaner.
Old Jul 1, 2003 | 09:15 AM
ion_four's Avatar
Default Re: (VaporTrail)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VaporTrail &raquo;</TD></TR><TR><TD CLASS="quote">
if air was going by the rings, that would mean less air in the chamber thus a richer mixture, not leaner. </TD></TR></TABLE>
I think he meant oil vapor (though I'm not him).
Old Jul 1, 2003 | 09:59 AM
earl's Avatar
Default Re: (ion_four)
It actually sucks oil from the pan, burning it with the normal combustion and causing more heat and detonation. Vicious cycle.
Old Jul 1, 2003 | 11:13 AM
VaporTrail's Avatar
New User
well oil vapor will be brought up with blow by, yes, and that mixes with the gas and lowers effective octane, thus causing detonation.
Old Jul 1, 2003 | 12:37 PM
Muckman's Avatar
Moderator in Chief
How could this have been caught? Simple compression test?
Old Jul 1, 2003 | 07:41 PM
Turboteggy's Avatar
Probably. The main reasons for the failure are the rings and me. I upgraded to a much larger turbo, but hadn't gone in to re-tune the Hondata, so I may have been slightly underfueling.
Old Jul 1, 2003 | 07:58 PM
TurboSedan's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboteggy &raquo;</TD></TR><TR><TD CLASS="quote">Probably. The main reasons for the failure are the rings and me. I upgraded to a much larger turbo, but hadn't gone in to re-tune the Hondata, so I may have been slightly underfueling.</TD></TR></TABLE>
No offense, but you say you upgraded to a MUCH larger turbo and you thought you may have been SLIGHTLY underfueling? Due to the increase in power up top, you were screwed because of the old map. The detonation caused by the lean condition wore the rings, which then allowed the blow-by which then messed you up even further. Live and learn I guess!
Modified by TurboSedan at 9:49 AM 7/2/2003
Old Jul 1, 2003 | 10:13 PM
b18cx's Avatar
DAMN!!!! I'm still impressed with the 17psi, 40k, and <U>2 and a half years of use/abuse. </U>
Old Jul 1, 2003 | 11:25 PM
SiR Kid's Avatar
New User
Default Re: Blown Leitner & Bush block - pics inside (b18cx)
Lag doesn't cause a richness problem because the ecu only see's LOAD at rpm levels, not length of time of lag.
How do you think you can get on it at 2500 rpm, and it lags and builds boost, or you can get on it at 6000 and have instant boost, and the ECU is tuned for both situations?!
Reverse blowby under high vacuum situations can suck oil vapor from the crankcase and cause the mixture oround the outside of the piston to be leaner, and therefore hotter, causing the burnoff of contaminants. My mustang has a pretty bad reverse blowby issue, but no real blowby. It still has me stumped. ICE's are some voodoo hoodoo things, even 120 years after their invention.
BTW, are you in the habit of engine braking at all? When braking, do you downshift and let out the clutch to let the car slow down on the engine? This can cause premature ring failure, causing the shown effects.
GT500FTW
Jan 5, 2013 02:35 PM
got wide
Sep 4, 2007 03:55 PM
IgnitionZ05
May 8, 2007 10:03 PM
hondaapi
Apr 28, 2005 10:09 AM
Rod.
Dec 28, 2003 12:38 PM
