Blow off valves
Old Aug 6, 2007 | 08:01 AM
Un Palo's Avatar
Default Blow off valves
Hi to all members i would like to know what is the correct way to set the blow off valve- Soft / Hard is there a formula you follow? I heard that the more air (Phsssss) sound is less air that is going to the engine, just need help with this Thanks in advance
Old Aug 6, 2007 | 08:10 AM
da_dude's Avatar
Adjust it to the point where there will be no leaks from the bov and no compressor surge from the turbo. That is what the adjustable screw is for.
Old Aug 6, 2007 | 09:23 AM
GSROWNSU's Avatar
bump for answers...idk if this is a noob question or not but i always wondered the same thing how to adjust spring pressure on a bov.
thanks
Old Aug 6, 2007 | 09:31 AM
da_dude's Avatar
Default Re: (GSROWNSU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSROWNSU &raquo;</TD></TR><TR><TD CLASS="quote">bump for answers...idk if this is a noob question or not but i always wondered the same thing how to adjust spring pressure on a bov.
thanks</TD></TR></TABLE>
If you adjust it too tight then the bov won't release pressure, therefore the pressure will be push back to the turbo spinning the turbine backward. That is what we would call it compressor surge. If you put adjust it too loose the bov might not be able to hold the pressure and leak boost. Therefore you will have a huge boost leak. So like I said before adjust it to where it cover what I stated above. Hope this will get you a idea. And you shouldn't worry about the bov sound too much. As long as it work the it's all good. Unless you are a true ricer and like that cool bov sounds.
Modified by turb20_vtec at 6:26 PM 8/6/2007
Old Aug 6, 2007 | 10:15 AM
Kyle R's Avatar
Default Re: (turb20_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turb20_vtec &raquo;</TD></TR><TR><TD CLASS="quote">
If you adjust it too tight then the bov won't release pressure, therefore the pressure will be push back to the turbo spinning the compressor wheel backward. That is what we would call it compressor surge.</TD></TR></TABLE>
Old Aug 6, 2007 | 04:55 PM
Un Palo's Avatar
Default Re: Blow off valves (Un Palo)
Thank you very much for all your help
Old Aug 6, 2007 | 07:56 PM
laocivic's Avatar
so how do you know when it wont leak
Old Aug 6, 2007 | 08:34 PM
da_dude's Avatar
Default Re: Blow off valves (laocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laocivic &raquo;</TD></TR><TR><TD CLASS="quote">so how do you know when it wont leak</TD></TR></TABLE>
When you are getting boost pressure on whatever spring rate your internal/external wastegate is set at. If not, you are leaking somewhere. It could be from the bov and it could be from somewhere else.
Old Aug 6, 2007 | 08:42 PM
Kyle R's Avatar
Default Re: Blow off valves (turb20_vtec)
Trial and error.
xkrntamax
Dec 3, 2007 01:55 PM
14bcoupe
Mar 1, 2005 01:03 PM
bearboy80
11
Apr 25, 2003 07:07 AM
civickid77
Oct 27, 2002 02:33 PM
echo999
May 14, 2002 08:54 PM
