what kind of cams should i use for boost
what kind of camshafts should i use for boost
hi i was wondering what kind of camshafts should i use in my h22? iam planning to turbo charge it and tune it to a s300 hondata could anyone tell me witch camshafts should be good?
Modified by killingtwobirds at 10:04 PM 8/6/2007
Re: what kind of camshafts should i use for boost (killingtwobirds)
What kind of numbers are you shooting for? Stock block? Stock head?
Basically start with your ultimate goals and work backwards being realistic with your budget at mind as you do this
Re: what kind of camshafts should i use for boost (xenocron)
i heard that stock cams work great with turbo set ups. i wouldnt worry about cams at the moment, and just focus on getting all the little necessary stuff and make sure it runs correctly. after that, i would probably look at cams if you want a little adjustment
iam planning to try run 15- 20 lbs trying to push 400-500. so the stock camshafts should be good for this set up i was planning to buy skunk 2 stage 2 turbo camshafts but i was wondering if their is anything better? thanks
ImageWorks
04-20-2006 04:23 PM
CimorelliCRX
07-27-2002 02:04 PM
