Blow off valve not functioning
Old Jun 9, 2008 | 06:00 AM
accord99power's Avatar
Default Blow off valve not functioning
i first had the BOV t'd into the top port of the throttle body, and the blowoff is really weak and seems late, then i t's it into the FPR, same thing regardless of the adjustemnt really loose or down tighter. my motor isnt tuned yet, but even taking it to about 3-4k it doesnt blow off loud.
Old Jun 9, 2008 | 06:15 AM
standbackimapro's Avatar
Default Re: Blow off valve not functioning (accord99power)
Just try connecting it to a different vaccumn source
Old Jun 9, 2008 | 06:44 AM
Default Re: Blow off valve not functioning (standbackimapro)
would having an untuned motor make a difference? if i use a different source i can just use the t on the fpr for the boost gauge right? or should i use a different hose besides the fpr for the boost gauge?
Old Jun 9, 2008 | 06:46 AM
twkdCD595's Avatar
on only a light load as your driving since untuned, revving to 3-4k rpm with low boost... your not going to hear a very loud release.
it is opening though right?
Old Jun 9, 2008 | 06:48 AM
Default Re: Blow off valve not functioning (twkdCD595)
its whistling after shift if thats what you mean sorry bro this is my first turbo kit.
Old Jun 9, 2008 | 06:55 AM
twkdCD595's Avatar
no problem, at least your making an attempt to learn things.
as long as your getting a release when you lift off the throttle and its not surging then your ok (you can google for video of what surge sounds like). if your worried about the bov reacting too slowly you may want to run it its own vac line direct from the intake manifold instead of tee'ing off a source... if it seems to react quickly enough though you are ok tee'd.
the more boost the more noise though basically, so with a light load your probably not even hitting full boost at that rpm which is good since your untuned you dont want to be beating on it too much. once your tuned and you can rev the car out and will be wot/ full boost, the bov release sound will clean up and get louder.
what kind of bov btw?
Old Jun 9, 2008 | 07:28 AM
your the man one last question, you said directly to the thorttle body the BOV or the boost gauge? i was using the port that was caped off for the BOV and theres a def vacuum on the port that should be fine right?
Old Jun 9, 2008 | 08:04 AM
boostedcivicsir's Avatar
Mr. Badwrench
when you say it is teed into the top port on the throttle body, which one?
if its the one going to the evap can, thats venturi vac if i remember, and even so i dont think that source is sufficient enough, imho, a vac manifold is the way to go, or tee off of the pcv valve.
Old Jun 9, 2008 | 08:16 AM
Default Re: Blow off valve not functioning (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">when you say it is teed into the top port on the throttle body, which one?
yah theres 3 top ports behind my throttle body on my f23, 1 is the fpr, 1 is the canister, 1 is caped off, i used the fpr, and the caped off one same results. im thinking to use the caped off port for BOV and the T on the fpr for boost gauge, or
Old Jun 9, 2008 | 08:20 AM
Mr. Badwrench
i think the bov needs a larger boost reference. try teeing it off of the pcv. leave the fpr reference alone. sounds like you need a vacuum manifold.
Old Jun 9, 2008 | 09:08 AM
ill will try the pcv valve i guess ill know if my pcv valve needs to be replaced from now on if the bov changes its tone, haha. thanks for the help man!
Old Jun 9, 2008 | 09:30 AM
Mr. Badwrench
np.
T9U4ReBgO
Dec 20, 2007 03:10 PM
98_4drCivic
Sep 6, 2005 09:10 PM
vtec-adykt
Jan 11, 2005 10:06 AM
ludelvr
Aug 25, 2002 10:40 PM
quikrpm'z
Jul 2, 2001 10:57 AM
