Maxrev bov not working?
Old Mar 27, 2003 | 01:01 AM
buh_buh's Avatar
Default Maxrev bov not working?
I'm pretty sure its hooked up properly (vacuum line hooked up from end of bov to IM), but all I hear is compressor surge. Anyone else have problems with Maxrev bov? Or is that just how it sounds?
Old Mar 27, 2003 | 01:17 AM
dirtySOHC's's Avatar
Default Re: Maxrev bov not working? (buh_buh)
positive there are no leaks in the line?
mine sorta sputters at low boost but is very distinctive at full boost.
Old Mar 27, 2003 | 10:45 AM
buh_buh's Avatar
Default Re: Maxrev bov not working? (dirtySOHC's)
I'll try to replace the line today, but I am VERY sure there are no leaks in the line. Even if there was a small leak in the line shouldn't it even blow off a little bit?
Old Mar 27, 2003 | 12:01 PM
god damn it. you making this post made me wanna check if my mine was working properly and too my surprise its NOT. that sputter was ****** surge. i never heard it before so i didnt know
i unscrewd the BOV and noticed that the peice inside didnt move very freely, it didnt move at all. so wat i did was sand it all around smoothly so that while in the "chamber" it moves freely. but still now blow off. i checked my lines switched b/w vacuum sources and still the same thing
anyone else have this problem w/theirs.
Old Mar 27, 2003 | 12:05 PM
buh_buh's Avatar
yeah, I thought it was the BOV too at first, but I know for sure its compressor surge. Haha, so can anybody help us out then?
Old Mar 27, 2003 | 12:09 PM
i got 200 miles on the turbo i hope i didnt damage the **** too much..........god damn it. you dont know how ****** mad i am.
first it was the DP not fitting, now the BOV is ****.
imma bout to buy the HKS SS off of groupbuycenter if i dont figure this out soon.
sorry for my language...............very frustrated here
Old Mar 27, 2003 | 12:12 PM
buh_buh's Avatar
don't worry man, I've had mine on for longer than that. I heard the Greddy Type-S uses the same flange as the maxrev one. Can anyone confirm?
Old Mar 27, 2003 | 12:46 PM
evoeone's Avatar
loosen it, when i put on my type s greddy, i could hear a bit of surge, then the treademark greddy whistle, i just loosened it and i was fine,
try loosening the spring
Old Mar 27, 2003 | 12:52 PM
Default Re: Maxrev bov not working? (evoeone)
been done
Old Mar 27, 2003 | 01:09 PM
SiRkid's Avatar
uh oh
Old Mar 27, 2003 | 01:10 PM
buh_buh's Avatar
you can't loosen the Maxrev BOV. its non-adjustable. I tried lubing it up with some bike grease, but still all I hear is compressor surge. I guess I'll go out and buy a new bov.
Old Mar 27, 2003 | 01:27 PM
**** it.....i just ordered an HKS SS just now, it was wat i wanted in the first place so i aint that mad......but ****
wow how the money flies when you go turbo
Old Mar 27, 2003 | 01:29 PM
you can loosen it up a little bit by unscrewing the cap a little.........but it didnt work for me. i was also thinkin about cutting the spring some but i havent done that yet.
Old Mar 28, 2003 | 02:32 AM
buh_buh's Avatar
yeah, me and Legendboy tried everything. We cut like 60% of the spring off and sanded down part of the side so the piston won't be rubbing up against the side. You can basically push it up wiht your finger, but it still won't blow off, so a friend of mine helped me ghetto rig up a charge pipe and he lent me his turboxs for the time being. STUPID MAXREV BOV
Old Mar 28, 2003 | 07:42 AM
i did the same exact thing you did. because at first the damn thing was stuck closed. so i was like "oh let me just do this" womp womp...........still none.
i should be getting my HKS SS tomorrow..............then it will be happy boosting.
Old Mar 28, 2003 | 09:04 AM
buh_buh's Avatar
well the spring is cut like tons now, it can basically move if I shake the bov haha. So I'm gonna hook it back up today and see if it works.
Old Mar 30, 2003 | 01:28 PM
buh_buh's Avatar
k I've sort of fixed it. I sanded down the edges more, and I cut the spring so its like 5" now. And now I can hear it blow off AND I hear compressor surge at the same time. Kinda weird. But maybe if I cut the spring more it'll just blow off completely. I think either way this BOV is a POS and I'm probably just going to buy a new one anyways.
Old Mar 30, 2003 | 02:27 PM
SiRkid's Avatar
this is no good..
anyone reported this to max rev?
Old Mar 30, 2003 | 04:26 PM
redline201's Avatar
Default Re: Maxrev bov not working? (SiRkid)
this sucks
im starting to regret buying the maxrev kit
Old Mar 30, 2003 | 04:46 PM
buh_buh's Avatar
Default Re: Maxrev bov not working? (redline201)
yea im regretting buying the maxrev kit too. Shoulda just bought the turbo, intercooler and manifold and ditched the rest. Ah well. Live and learn.
Old Mar 30, 2003 | 04:49 PM
this sucks
the kit is nice its just the BOV that is a POS or at least for me and this other guy. anyone else have this BOV
i cut my spring as well and i was getting blow off and surging at the same time so i loosened it as much as possible and it would blow off completely but the spring is not strong enough to hold boost and would bleed off.
Old Mar 30, 2003 | 11:21 PM
buh_buh's Avatar
yeah I did the same thing today. I'm getting a lot of boost leak from the BOV. I think I'm going to try to put some washers in and see if I can find a level where I don't leak boost but no no compressor surge.
v.i.gsr
Jul 13, 2011 04:09 PM
Dan_Roc
Feb 6, 2007 12:55 PM
LSEGHATCH
Oct 29, 2005 04:25 PM
patdemps
Jun 1, 2004 01:51 PM
Dancing is Forbidden
Jul 20, 2003 05:18 PM
