B18C6
Old Jun 19, 2003 | 01:17 AM
swlabhot's Avatar
Default B18C6
What is the stock bore size of this block? I'm planning on building internals. What details do I need to specify for the Rods, Pistons and head studs to make sure that I order the right ones? Bore size, compression etc...
TIA
Old Jun 19, 2003 | 02:35 AM
MiraiZ's Avatar
Default Re: B18C6 (swlabhot)
same as JDM b18cR
Old Jun 19, 2003 | 05:17 AM
Plan B's Avatar
Default Re: B18C6 (MiraiZ)
It's gonna be 81 mm just like any other b series block with the natual exception of the b20, 84 mm. However, it is my suggestion that you bore the block, service limit is .25 over, do that, most all pistons are available in .25 overbore and that will give you a slight increase in boresize (very very slight) and will ensure that you have a proper sleeve all the way down, given that you take the block to a worthy machine shop.
Expect to pay between $150-$200 for good machine work, cleaning, bore, hone.
That is my suggestion.
Pretty cool however that you are getting a c6, where are you getting it from?
Old Jun 19, 2003 | 05:38 AM
austrian type-R's Avatar
Default Re: B18C6 (Plan B)
B18C6 is the European engine code. Where do you live?
Old Jun 19, 2003 | 11:28 AM
swlabhot's Avatar
Default Re: B18C6 (austrian type-R)
I'm in UK hence C6 and not C5. I don't plan on resleeving it, just rods and pistons. So would it be best to use the oem headgasket and just drop in lower compression pistons like 9.1?
Old Jun 19, 2003 | 02:23 PM
swlabhot's Avatar
Anyone know if the rods and pistons in the C5 is identical in everyway to the C6??
Old Jun 19, 2003 | 02:30 PM
Ex-ITR5874's Avatar
pistons are different... The c6 runs higher comp.
Old Jun 19, 2003 | 02:46 PM
swlabhot's Avatar
Default Re: B18C6 (ITR5874)
yeah but thats all right? Say if I get rods and pistons for the C5 it will fit the C6 straight?
Old Jun 19, 2003 | 02:50 PM
Ex-ITR5874's Avatar
yes.. The block is interchangeable....
Old Jun 19, 2003 | 03:03 PM
swlabhot's Avatar
Thanks!
Old Jun 19, 2003 | 04:46 PM
v's Avatar
v
Just out of curiosity, what octane is your premium gas in europe?
Old Jun 19, 2003 | 10:50 PM
Default Re: B18C6 (v)
hehe, anotherone is going turbo?! Well, use stock headgasket, I use too
Old Jun 19, 2003 | 11:55 PM
MiraiZ's Avatar
all b-series pistons except for the b20 are interchangeable....just pick the compression you want and plug away...otherwise get some forged aftermakets...all 81.0mm will work..81.5 (like mine) gives to you a slightly bit more torque but you'll need to bore it out a bit
Old Jun 20, 2003 | 12:33 AM
strepto's Avatar
Hi!
Didn't jun release a 2l stroaker kit for the B18Cx series? I know Toda got some kickass stuff internal "leet" parts as well. My DC5R will be all Toda
Old Jun 20, 2003 | 12:41 AM
Default Re: B18C6 (strepto)
why bothering with stroker kit? The bore/stroke ratio of the B18C is not that good anyway and with stroker kit it gets even bader. Best bore/stroke ratio would be 81x81 or 85x85 or something. The B16 is perfect. I would go with 85 or even 87mm sleeves and stock stroke. 87x87 bore/stroke ratio owns! and you can rev as high as stock and more. With stroker kit revs more than 9000 sucks and you need more revs if you want run aggressive cams and make power.
Stroker kits are much overpriced too, sleeves and high compression pistons for n/a is best way, same for turbo......but bore/stroke ratio is not so important on boosted cars than on n/a cars.
93delsolJDM
Feb 13, 2011 11:25 PM
stocker2shocker91
13
Oct 17, 2007 09:33 AM
Propulsion
Sep 28, 2003 12:21 PM
phiberoptik
Aug 27, 2003 10:19 AM
Chris Benoit
Aug 10, 2003 09:22 PM
