block guard
Old Aug 25, 2009 | 04:49 PM
j0keefe21's Avatar
Default block guard
ok i am about to start building my turbo bottom end. i am looking for about 300whp on a t3 t4 turbo my question is, is a block guard necessary for this set up and when does a block guard become necessary? thanks guys
Old Aug 25, 2009 | 04:58 PM
kccord's Avatar
Default Re: block guard
Is your engine open deck?
My F22 is open deck, one workshop offered that I should put in a block guard, I said no as for them it will do more damage than good if there is a slight miss in installation.
People said block guard is a killer for cracked sleeves etc etc since it has different expansion rate that the engine block itself under heat.
Old Aug 25, 2009 | 05:08 PM
mike_s13_drift's Avatar
if you cant afford a sleeved block you might as well have a little more protection. just make sure its a repitable shop that installs it.
Old Aug 26, 2009 | 12:50 AM
j0keefe21's Avatar
the motor is a d16z6 by the way. i dont want to do it unless i have to becuase i know if its screwed up at all it will mess up everything.
Old Aug 26, 2009 | 01:08 AM
TurboCivic11's Avatar
I dont believe block guards prevent cracked sleeves. They...if anything, might help under high rpm or high boost keep the cylinders from moving around. Its been my experience that if a sleeve is gonna crack, its gonna do it wether or not the guard is in there. I steer all my customers away from them.
Old Aug 26, 2009 | 05:47 AM
dephtone's Avatar
I bought a motor that ended up having a block guard in them, I have read, although I can't confirm this, that if you try and remove a block guard it has a chance to make your cylinder walls not round anymore.
I was going to try and remove mine as it is just pressed in there, however I didn't want to take the chance in ruining my cylinder walls.
Old Aug 26, 2009 | 07:04 AM
CerealKiller's Avatar
A block guard is just that a "BLOCK GUARD". It doesn't prevent sleeve cracking, what it does do is help prevent your block from becoming non - resleevable. So if your going to do high boost, I recommend sleeving your block to begin with.
Old Aug 26, 2009 | 06:40 PM
j0keefe21's Avatar
what are we considering high boost here?
Old Aug 26, 2009 | 09:19 PM
jdm inc's Avatar
I agree! If you going for high boost, Just get the block sleeved.
360infinite-usa
Jun 26, 2012 12:42 PM
Captian_Honda
Mar 21, 2005 02:12 PM
jspeedy
Mar 18, 2004 06:49 PM
slug
Jan 21, 2004 10:29 AM
Nextelbuddy
Jun 18, 2003 08:01 AM
