Blew Engine, Need Diagnosis.
Old Jul 15, 2004 | 06:15 PM
SC61HB's Avatar
Default Blew Engine, Need Diagnosis.
Well, I have a turbo JDM ITR with a Drag 3 kit. Used Hondata S200B, RC 550's, etc. I boosted 6.5 psi, and got 250/183 on the dyno. Today, I went to start my car up, and it smoked alittle, but nothing unusual. Then when I started driving, smoke was pouring out of my muffler and starting to come from under my hood. I limped her home (about 2 miles), and popped the hood. Oil was all over my firewall. Oil looked like it spewed out of my breather on the valve cover. I then did a compression check and came up with these numbers:
- #1 130'ish
- #2 240
- #3 245
- #4 0
I am very sure that my ringlands went. I didn't notice any knocking or anything before I shut her down. Just wondering if you guys can assure me that my ringlands did infact go, and that there's not a hole in my block somewhere. If the ringlands just went, that's a heck of alot better than having a hole in the block.
Old Jul 15, 2004 | 06:23 PM
desert eagle's Avatar
Default Re: Blew Engine, Need Diagnosis. (zgrieger)
sorry about your engine bro. anybody can tell you anything right now, but the ONLY way to REALLY know what is wrong with your engine is to break into it. its probably not what you wanna hear ( trust me i've been there) but its the truth. good luck gettin it back up man.
Old Jul 15, 2004 | 06:28 PM
B18C1CYA's Avatar
any coolant mixing with oil or white smoke? what color is the smoke from your tailpipe? , first i would do a leak down test and see what that shows just to make shure, then pull your head and inspect the damage, it sounds to me ringlands but check the easy things befor you rip in to her
Old Jul 15, 2004 | 07:47 PM
racinskittle's Avatar
Default Re: Blew Engine, Need Diagnosis. (B18C1CYA)
prolly the rings. But like they said before. Check your coolant level as well. Could be your HG. But if it turned over, then more than likely there's no hole.
Old Jul 15, 2004 | 08:02 PM
SC61HB's Avatar
Yeah, it sucks, but it'll be bigger and better. Plus it's a good learning experience rebuilding an engine.
I'm pretty sure I didn't blow a hole in the block. My coolant level is normal, but white smoke was coming out of the tail pipe. I'm sure if there's a hole in the block, it would be knocking and I would be losing oil like mad.
Anyway, I'm gonna try to get the entire head off tomorrow, then remove the block this weekend. I'll keep you guys posted.
Old Jul 15, 2004 | 10:24 PM
98gsrTEG's Avatar
the only way i can think of that you got alot of oil on your fire wall and in your engine bay would be in fact a hole in the block. if it is on your firewall it could be in back so it would be hard to see. when your ringlands go, you dont spew oil into the engine bay. you will spew it out of the exhaust.
it may not be what you wanted to here, but i don't know of any other way it could have heppend.
unless the ringlands were soo bad that you got enouph blow by to pressureize the crank case and shoot the dipstick out of the block. or also the valve cover.
Old Jul 15, 2004 | 10:35 PM
SC61HB's Avatar
Default Re: Blew Engine, Need Diagnosis. (98gsrTEG)
All the oil I saw was in-line with the breather nipple on the valve cover. Oil was on a couple of injectors, fuel filter, etc. There was also oil dripping from the nipple. I got under the car and there was no apparant hole in the block. I sure hope there isn't.
I swiped my finger on the inside of my exhaust tip, and it's oily.
Modified by zgrieger at 1:53 AM 7/16/2004
Old Jul 16, 2004 | 12:29 AM
pngfolife's Avatar
100% sure it's the ringslands. I toasted my first motor the same way. Sometimes, the stock cast pistons just can't take the heat and pressure of even very low boost. I'll post pics of my piston damage at only 5 psi. I'm waiting on WTDR to send me my activation confirm.
Old Jul 16, 2004 | 12:45 AM
pngfolife's Avatar
You like?
Old Jul 16, 2004 | 01:38 AM
ATS*Mark's Avatar
OG triple OG
Default Re: Blew Engine, Need Diagnosis. (pngfolife)
10 lbs tuned + bad gas = that
Old Jul 16, 2004 | 01:51 AM
LBR92DA-T's Avatar
Default Re: Blew Engine, Need Diagnosis. (Hella_JDM)
i bet i can beat that... no fuel + 14 psi = this
I grenaded the **** out of my motor when my bosch fuel pump died.. haha.. all the ring lands were melted. thats #1 piston, #2 had a smaller hole in it and i guess it got better for 3 and 4. my machinist leaves it on his desk and everytime i go there he tells me that people look at it and ask wtf happened to it..
Old Jul 16, 2004 | 03:53 PM
pngfolife's Avatar
Default Re: Blew Engine, Need Diagnosis. (LBR92DA-T)
Hella and LBR, your **** is pretty nasty. My motor ran rough at idle and power was down slightly at high RPM.
Zgrieger, your piston probably looks more like mine than theirs... ...at least I'd hope so...
Old Jul 16, 2004 | 04:23 PM
SC61HB's Avatar
Well, I yanked the head off today. I was pretty relieved. The head wasn't damaged at all, none of the sleeves were cracked, and there weren't any holes in the block that I could see. Here are the pics of number 4 piston and cylinder. Number 1 piston looked like it was starting to melt alittle, but it's not worth posting the pics of #1.
THE PICS:
Old Jul 16, 2004 | 04:29 PM
LBR92DA-T's Avatar
ehhh thats not that bad.. hehe... time to buy a dart block.. hehe turns out i have a new one for sale.. hehe
Old Jul 16, 2004 | 05:25 PM
SiRkid's Avatar
that sucks..that thing is definately gonna need a bore and hone to be back to normal..looks like it ran really lean
Old Jul 16, 2004 | 05:34 PM
SC61HB's Avatar
Default Re: Blew Engine, Need Diagnosis. (SiRkid)
Well my plans for the new block are:
- Bore out to 81.5mm and hone
- CP 81.5mm 9.8:1 pistons
- Eagle 900hp H-beam rods w/ARP 3/8" 2000 rod bolts
- ACL Bearings
- ARP headstuds
- New Honda Oil Pump
- All necessary seals, gaskets, o-rings, etc.
I want to put down 350hp with this setup.
Old Jul 16, 2004 | 05:36 PM
B18C1CYA's Avatar
well sound like a nice platform, and will hold your goals nicely
Old Jul 16, 2004 | 06:55 PM
SiRkid's Avatar
that set up with proper fuel and turbo can make way more then 350
but it doesnt hurt being quite safe goodluck
Old Jul 16, 2004 | 10:37 PM
1.8LHatch's Avatar
that ******* sucks dude
Old Jul 16, 2004 | 10:51 PM
SC61HB's Avatar
When I pulled my head off, I looked at the bottom of the valves they looked okay. Then when I got to looking at them, the #4 cylinder where all the damaged occured, I looked at the exhaust valves for that cylinder. They look like they are burnt. They are rough, and don't look like all the other exhaust valves. Here's a pic, tell me what you think.
#4 Exhaust Valves:
Compare those to the #3 exhaust valves:
Again, tell me what you guys think. Do you think I need to replace those two exhaust valves? If so, do I just need to replace those two or do all the exhaust valves?
Old Jul 17, 2004 | 07:29 AM
B18C1CYA's Avatar
my valves looked the same way when my motor blew up, i han mine glass beaded and they where like new, i think it is just soot from burning oil,
Old Jul 17, 2004 | 08:24 AM
boostedt3to4e's Avatar
OUCH does not look good at all... i would just see if u can get the valves cleaned up and refinished..
just make sure they are straight and not bent...
u might even want to flow the head better for the boost since u are goin all out with the block and get valvetrain upgrade.....more flow=better boost......
Old Jul 18, 2004 | 12:06 AM
pngfolife's Avatar
Default Re: Blew Engine, Need Diagnosis. (boostedt3to4e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedt3to4e &raquo;</TD></TR><TR><TD CLASS="quote">OUCH does not look good at all... i would just see if u can get the valves cleaned up and refinished..
u might even want to flow the head better for the boost since u are goin all out with the block and get valvetrain upgrade.....more flow=better boost......</TD></TR></TABLE>
More flow=more power per pound of boost, not more boost. Boost is controlled by the wastegate regardless of valvetrain.
Just get stainless steel valves, they don't burn as easily. Going oversized will yield more power over stock sized valves.
Old Jul 18, 2004 | 06:33 AM
Sunrise City Rider's Avatar
Not bad, easy enough to fix...You'll be fine with what your'e doing...Valves look good...Just refresh the head with new valve seals/resuface/cleaning and do what you are gonna do with the block...Slap on a stock headgasket and torque down the ARP Studs...Check out the turbo for any damage and invest in a catch can...
Old Jul 19, 2004 | 11:21 AM
SC61HB's Avatar
Okay, here's what I'm going to have done to my head/block by a local machine shop. If some of this stuff isn't necessary, let me know. Also, if I left some things out, let me know also.
- Clean Head
- Pressure Test the head
- Bore Block .5mm over
- Hot Tank block
- Check Crankshaft
Alan42978
Jan 16, 2008 06:06 AM
T3T495GSR
Apr 19, 2003 10:04 PM
enabi
13
Sep 19, 2002 08:24 AM
Speed PHreak
Aug 30, 2002 07:47 PM
SilverLudeSi
May 6, 2002 04:52 PM
