is there a formula to calculate this?
Old May 28, 2002 | 08:33 PM
ceemarun's Avatar
Default is there a formula to calculate this?
ive searched and can only come up w/ specific scenarios, but none of them matched my own. if i get larger injectors (thinking about some 450cc dsm ones), what disc should i be using on the fmu? im sure a lot of you guys know from experience, but is there a certain way you can calculate it?
Old May 28, 2002 | 08:55 PM
Giuseppe's Avatar
Default Re: is there a formula to calculate this? (ceemarun)
your honda motor wont be able to idle properly with
only those bad boys in there, look into the 'AFC hack'
to eliminate FMU disks, or go with a fully adjustable
FMU like a cartech unit..
hth
Old May 28, 2002 | 08:59 PM
ceemarun's Avatar
Default Re: is there a formula to calculate this? (Giuseppe)
hmm, so i guess i should stick w/ my stock ones and the 12:1 disc til i can afford a standalone
Old May 28, 2002 | 11:40 PM
Giuseppe's Avatar
used a good inline pump with that 12:1 disk
a Bosch pump is recomended..
or..invest in a VAFC and use the hack method to
get those 450cc DSM injectors working nicely..
hth
Old May 28, 2002 | 11:53 PM
ceemarun's Avatar
a walbro intank 255lph pump is on the way for me
Old May 29, 2002 | 12:07 AM
Sonny's Avatar
450cc injectors + 12:1 FMU = large amounts of gas shooting out your tailpipe!
You do not need an FMU at all with injectors that size. You will need some way to properly control them at idle/partial throttle because they are gonna run suuuper rich. The VAFC Hack or a standalone like Hondata is something you'll need to look into.
Sonny
Old May 29, 2002 | 12:17 AM
ceemarun's Avatar
Default Re: is there a formula to calculate this? (Sonny)
ok, so i'll buy the larger injectors when i get some sort of tunable devices. im planning on a standalone later anyway, so i'll be ok w/ the stock inj w/ the 12:1. i just heard i can get larger injectors if i change the disc rating, like 440cc's and a 6:1.
Old May 29, 2002 | 05:53 AM
X2BOARD's Avatar
Wouldn't the upgraded intank +FMU+ stock injectors do some good till then ?
Old May 29, 2002 | 07:04 AM
Giuseppe's Avatar
amongst the 'regular' boost junkies on this board
and i agree the pump above wont handle the high pressures
associated with stock injectors ans the 12:1
ask around and look into a bosch pump, find one
used from a reputable source and its a step above from
the walbro
hth
Old May 29, 2002 | 07:06 AM
ATYPR's Avatar
Get the DSMs, adjustable FMU, and an AFC. I have used this set-up on our 89 with a b17a and a T3/T4. Works great!
Old May 29, 2002 | 08:28 AM
dbman96's Avatar
New User
Default Re: is there a formula to calculate this? (FUCATYPR)
Agreed except for the adjustable FMU part - with DSMs and an AFC you can run rich right up to around 9-10 psi boost with the STOCK fuel pump and STOCK FPR, no FMU needed.
Old May 29, 2002 | 10:01 AM
ceemarun's Avatar
Default Re: is there a formula to calculate this? (dbman96)
my situation is that im looking for something to run at only about 6psi daily until i can get a standalone. when you mentioned how i can run the DSMs and a VAFC, is that a good permanent setup? if i'll be safe w/ running that at no more than 6lbs daily, i might go w/ that since its a lot cheaper.
Old May 29, 2002 | 10:50 AM
SIK IN DA HED's Avatar
New User
fmu 12:1, inline fuel pump, and stock injectors. or you can get 310s and run a 8:1. the best bandaid setup for your nonstandalone fuel setup.
chirp3rd
Feb 3, 2003 04:56 PM
freeplay
Dec 1, 2002 09:41 AM
pelotudo
Sep 9, 2002 08:52 PM
_Endless_
Sep 2, 2002 01:28 AM
KoRE
Jun 25, 2002 08:52 PM
