Is this a BIG deal?
Old Feb 25, 2007 | 02:02 PM
tallblondkid's Avatar
Default Is this a BIG deal?
been boosted for about 2 weeks or so and i noticed this just now.
the bolt snapped and the metal ring thing cracked
Its a Precision SC turbo, like 2 weeks old
Old Feb 25, 2007 | 02:16 PM
blinx9900's Avatar
Default Re: Is this a BIG deal? (tallblondkid)
it may effect the seal, thats about it, was the bolt over tightend? i believe precision has a 1 year warrenty against defects.
Old Feb 25, 2007 | 02:27 PM
SPOOLINmatt's Avatar
Default Re: Is this a BIG deal? (blinx9900)
you should find one of those rings relatively easy, and replace with a new bolt. Have the old bolt extracted. its not going to really affect anything at this point.
Old Feb 26, 2007 | 05:36 AM
White Smoke's Avatar
i my honda
Global Mod
Contact Precision, they should help you out with that.
Old Feb 26, 2007 | 05:53 AM
bag's Avatar
bag
Default Re: Is this a BIG deal? (White Smoke)
what causes that besides overtightening? or is it just a crappy turbo?
Old Feb 26, 2007 | 06:00 AM
xsi-t's Avatar
Default Re: Is this a BIG deal? (bag)
Looks like it was overtightened by someone and heating up cooling down didnt help. Call Precision. They will replace it
Old Feb 26, 2007 | 06:04 AM
bag's Avatar
bag
Default Re: Is this a BIG deal? (xsi-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsi-t &raquo;</TD></TR><TR><TD CLASS="quote">Looks like it was overtightened by someone and heating up cooling down didnt help. Call Precision. They will replace it</TD></TR></TABLE>
Precision will replace the turbo for free even though it's the users fault?
Old Feb 26, 2007 | 06:16 AM
mike1114's Avatar
holly amount of rust in "two weeks" batman!!!
Old Feb 26, 2007 | 08:07 AM
HiProfile's Avatar
Default Re: Is this a BIG deal? (mike1114)
As 99% of turbos have to be clocked to make them fit right, they technically wouldn't have to replace it if the user over-torqued a fastener. It would be like ARP giving you new headstuds every time you try reusing the studs you torqued to 105lb/ft [and stretched way beyond specs].
Chances are its just the bolt that snaped. Unless they use a different chra style, its ~1/8" wide mating surface around the chra, both sides cast iron, and its hard to deform that much material. The cracked ring is kinda odd, but seeing as how 2 bolts always have a split beneith them, I don't see it being a big issue.
Old Feb 26, 2007 | 11:00 AM
EJ1 wilcox's Avatar
I wouldn't worry about it at all. There are enough other bolts holding it in place.
If you are really paranoid then you could take the turbo off, remove the old bolt, and put a fresh one in there, but that would be a lot of work for no real benefit.
Old Feb 26, 2007 | 11:18 AM
xsi-t's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bag &raquo;</TD></TR><TR><TD CLASS="quote">
Precision will replace the turbo for free even though it's the users fault?</TD></TR></TABLE>
It's a single piece. It's not connected to the entire turbocharger. I have seen people overtorque these many times
Old Feb 26, 2007 | 11:24 AM
JDogg's Avatar
i wouldnt worry with it
Old Feb 26, 2007 | 11:32 AM
xsi-t's Avatar
Default Re: Is this a BIG deal? (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt worry with it </TD></TR></TABLE>
Nor would I. Torque it down. You will be fine. If you really want to replace it call up Precision
Old Feb 26, 2007 | 11:55 AM
what should these bolts be torqued to? turbine and comp?
Old Feb 26, 2007 | 11:57 AM
xsi-t's Avatar
E-mail Precision and ask. I cant remember off hand. I just feel where I torque them to any more
98TEG2NV
Oct 18, 2005 05:52 PM
RudeLude
Jan 3, 2004 12:49 AM
xkhalil333x
Dec 24, 2003 12:49 PM
ernald711
Aug 14, 2003 10:20 AM
elwood
Apr 14, 2003 12:31 AM
