Subframe bolt ?
Subframe bolt ?
If you deal with your suspension as much as I do then
you should be able to visualize what im talking about.
But if you cant i drew up a picture that will help. Has anyone
ever broken the nut that conects to the lca bolt inside the
sub frame? The nut is welded to the sub frame so that you
can screw the lower controll arm bolt into the sub frame.
The sub frame is hollow and you cant hold the nut up to the
bolt to tighten it. Has this happened to anyone or am I the first?
What did you do if it happened to you?
Re: Subframe bolt ? (d15dude)
yeap, just found out mines jacked like that too like 3 days ago...imma get a new subframe....unless someone else has a better idea
Re: Subframe bolt ? (Peagreenhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Peagreenhatch »</TD></TR><TR><TD CLASS="quote">just get a new subframe. Junk yard..</TD></TR></TABLE>
okay mista balla in da escilade.
thanks for the obvious answer but I already have a new subframe,
and if anyone needs one I have a few extras.
Yeah I have broken the weld those welded nuts on two cars already. You have to cut a small square hole to fit your wrench under your subframe(side facing the floor) to hold your nut while you tread in your bolt with a rachet.. The nut might be a 14 or 17. I don't remember. Just throw on some tread locker too once you are at it. It is not a big deal guys.
aimbot
08-07-2008 03:03 PM
sonny0330
05-29-2008 06:53 AM
