Better spark/ignition options
Old Apr 22, 2014 | 04:22 PM
  #176
turbohatch96y7's Avatar
Default Re: Better spark/ignition options
Ill be looking forward to all the knowledge ddtech
Old Apr 22, 2014 | 04:25 PM
  #177
DDTECH's Avatar
Yea, me too, I'm still waiting to acquire it all.
Sarcasm
Old Apr 22, 2014 | 04:31 PM
  #178
wantboost's Avatar
Who is Mr Robot?
Yeaah well im the savior here so na nana na na .
I just wanted to update this because people think a component is always the fault when most of the time its not.
People need to take the time to learn how to use a multimeter and read a schematic.
first part made me go lolololol literally.
last part I wholeheartedly agree with.
Old Apr 22, 2014 | 04:36 PM
  #179
DDTECH's Avatar
Not gonna ly.. When I first got into the whole "import" thing, I was a idiot. Becoming a "real" thing Technician helped me learn so much, that's a fact.
Diag / Fixing right the first time, I've applied so much that I've learned from schools I've been too over to the performance world and its honestly helped me both businessly, and efficiently.. People that spend 200K+ on a car don't want to return, unless they absolutely have to.. I treat all of my customers now , like I do when I work at a dealership.
Old Apr 22, 2014 | 04:49 PM
  #180
Sarcasm
Since you're being sarcastic, you already know it all?
Im confused just a little
Old Apr 22, 2014 | 04:57 PM
  #181
DDTECH's Avatar
LOL. No. My reply was how I took your reply, I thought you were being sarcastic, if you weren't, My apologies.
Old Apr 22, 2014 | 05:03 PM
  #182
OH right I was being sarcastic but towards Wantboost lol. I like to mess with him a little here and there. Hes a cool guy in my book
  #183
DDTECH's Avatar
I was talking in regards to your response to me, But either way, its all good. Drinks on me.
Old Apr 22, 2014 | 05:17 PM
  #184
wantboost's Avatar
Who is Mr Robot?
I love you too lol
Old Apr 23, 2014 | 12:17 PM
  #185
$amGD3's Avatar
Swaggylicious
Ill update this for him.
He found a loose wire to the icm last week :cough: :cough:
It was hard to find! Even the tuner couldnt locate it with a multimeter
It was my lack of patience and shaking the **** out of the ecu/harness that actually undid the wire lol
SO technically, it was lose yet visually looked fine
Old Apr 23, 2014 | 01:33 PM
  #186
So you're saying I was right? Koo
Old Apr 23, 2014 | 02:29 PM
  #187
LightningTeg's Avatar
Community Builder
Happy to report my theory was correct. I put the shield back in the housing and walla, 30 lbs of boost. Damn it feels good lol. Now I need to get my Crane stuff back...
Old Apr 23, 2014 | 05:16 PM
  #188
wantboost's Avatar
Who is Mr Robot?
Yea it doesn't take much for voltage that high to arc around to places it's not supposed to go.
Old Apr 24, 2014 | 12:39 PM
  #189
$amGD3's Avatar
Swaggylicious
Dude you know Kaelan? He was a Tampa local
Old Apr 24, 2014 | 01:58 PM
  #190
Str8 outta Cliff's Avatar
That's crazy how that would make such a difference!
I wonder if I'm the only person reading this who is now trying to remember if they replaced that part last time they had the dizzy apart.
I can remember at least once changing out parts and after putting the cap back on you see the dust shield sitting on the bench. I'm pretty sure I would usually take the 2 minutes to replace it. Guess I'm going out to the garage...
Old Apr 25, 2014 | 01:15 AM
  #191
wantboost's Avatar
Who is Mr Robot?
Yea I've been friends with him since he was living in Va or wherever. he was debating moving here to the atl then decided to move to Tampa. I've been working in the grassroots drifting movement as well as working for FormulaD
when I heard about it tha Thursday I was floored and I don't really know what even happened
Old Apr 25, 2014 | 06:49 AM
  #192
$amGD3's Avatar
Swaggylicious
Nice man.
As disheartening of a loss it was, it was nice to see so many people from different walks of life honor him. I have friends that are heavy BMX dudes, 240 dudes, just general drifting dudes and shop/fab dudes and all were showing their respect. We even had a small meet down here in Tampa
Old May 26, 2014 | 06:05 PM
  #193
$amGD3's Avatar
Swaggylicious
Bump!!
Finally got everything and installing tomorrow
How are you guys mounting your summit box? I saw someone had it in the glovebox?
Also, how are you guys running the wires out of the dizzy for the bypass box?
Old May 26, 2014 | 06:09 PM
  #194
Turbo-LS's Avatar
Remove the wires from the dizzy is best.
Old May 27, 2014 | 04:35 AM
  #195
$amGD3's Avatar
Swaggylicious
What do you mean by that? I mean how haha
I'm trying to decipher the pictures in the instructions, did you just pulled the wires from the dizzy plug?
Old May 27, 2014 | 05:04 AM
  #196
Turbo-LS's Avatar
It's been so long since I did mine. Pretty sure the three wires that come out are the two on the two wire connector and the input signal wire from the ecu. Took coil and ignitor out and the three wires going to them. Then you use the distributor side of the two wire plug to connect power to the icm bypass and switched 12v to the summit on the black/yellow wire. Then tach output from the summit box to the blue wire.
Youll want to raise your rev liit past where you want it in your engine software and set the rev limit on the ignition box where you want it. Its a soft limiter and doesnt bang real hard its holds steady RPM and sounds badass. You can hear in the burn out and 1st gear launch is holding on the limiter of the box.
Old May 27, 2014 | 05:16 AM
  #197
$amGD3's Avatar
Swaggylicious
Ok cool. I think everything will make more sense once I have everything in my hand
This may be a stupid question but was I supposed to buy a coil wire? Or did it come with the cap or crane coil?
Old May 27, 2014 | 05:21 AM
  #198
Turbo-LS's Avatar
The coil wire will come in the MSD cap kit. it also comes with special ends you will have to install on your current wires. Its pretty simple just follow instructions. Hopefully you purchased the 82922 cap and not the cheaper black one. Not sure what comes with that cap but I've had those caps come apart several times on me and other peoepl i know which is why I recommend the 82922 red pro cap. Also put a little blue loctite on the rotor screw
Old May 27, 2014 | 05:26 AM
  #199
$amGD3's Avatar
Swaggylicious
Yessir, bought the 82922 cap and the rotor. Summit box and Crane ps92 coil
Old May 27, 2014 | 03:35 PM
  #200
$amGD3's Avatar
Swaggylicious
I'm still confused about what to do now...
What wires do I not put back in the dizzy? I know the black/yellow is used and so is the yellow/green
But what about the blue wire?
And the instructions say something about a white wire
Wtf am I looking for here
