best turbo cam for turbo GSR besides CTR, ITR
setup is
stock GSR bottom end -- plans on building his spare gsr bottom this sumer
Full race stg 3 kit
arp head studs
oem headgasket
aeromotive a-1000 sump pump
aeromotive FPR
CCstg 5
stock GSR cams
oem ITR tranny with lsd
jun retainers
zex,comp cams vavle springs
stock valves ------------------------- need to upgrade what would be a good choice
now it was tuned by tony1 to 300whp @ 8 psi
he wants to rev it to about 9500 and still make power after he builds the bottom end @ turns up the boost
wich turbo cam would help him keep the tq flatt up to 9500 besides the infamous CTR ITR combo
help would be appreciated
-Blake
Full race stg 3 kit
arp head studs
oem headgasket
aeromotive FPR
CCstg 5
stock GSR cams
jun retainers
-Blake
Re: best turbo cam for turbo GSR besides CTR, ITR (THEDirtyDseriesWOOT)
You should ask Tony1; he went 160mph with CTRs so they're kinda hard to beat . Jeff Evans said (NOT A DIRECT QUOTE) on a street driven car he doesn't like the PRO 1s because the idle is pretty bad. I guess it all depends on what he's doing with the car.
i dont think the pro1s are the way to go for you. they have a lot of duration and overlap which works well for tony because he has low low back pressure. you definitely wont with a t3 hot side.
