which is the best setup
Old Oct 14, 2002 | 06:02 PM
yusoslo's Avatar
Default which is the best setup
whats up i posted in drag racing forum and didnt get much response. I am getting ready to do a motor swap and needed some insight. My goal is to have a low 13 to high 12 second street car. My car is a 95 civic coupe and i want these times on street tires. I am almost certian I will do a turbo, unless I can do all motor for less money. I just want an opinion on going with LS turbo or B20 turbo. I hear the B20's arent *** reliable, and if i can achieve these 1/4 mi times with a ls than it will be cheaper. Basically............Can i achieve low 13's with a LS turbo. And if so is it a better idea to keep it non-vtec (definitely cheaper ), and If you are reacing these times all motor can u tell me your setup.
Ls non-vtec +
t3-t4 turbo (turbonetics) +
hondata +
ls tranny +
stock bottom end if possible= 13's on street tires??????
Old Oct 14, 2002 | 06:09 PM
Jared's Avatar
Default Re: which is the best setup (yusoslo)
gsr turbo with a hondata
Old Oct 14, 2002 | 08:12 PM
yusoslo's Avatar
Default Re: which is the best setup (Jared)
bump
Old Oct 14, 2002 | 09:08 PM
BudaKai's Avatar
Don't use the vtec head, with a built block, turbo, P&P head, and standalone you'll be plenty happy with the results. I'm a fan of Vtec, yes, but it isn't always nessesary for every application. With a full race motor Vtec is useless, and that also added rotational weight on the crank. Less weight = faster spool and Mo Powa!!!
bigboom
Mar 26, 2010 07:00 PM
DA_Manny
Nov 6, 2007 03:35 PM
TeamMGIperformance
Nov 28, 2003 11:34 AM
sExy_TinKY
Sep 7, 2003 07:37 PM
skellator_thoj
May 17, 2002 10:30 AM
