Best non-vtec LS turbo HP #'s?
#28
Re: (brickonwheels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brickonwheels »</TD></TR><TR><TD CLASS="quote">redline of stock ls is 6800</TD></TR></TABLE>
Circa 91, sure. Else, 7200.
#31
#33
#34
Re: Best non-vtec LS turbo HP #'s?
Owner/Builder: Ricky Taylor @ Infamous Motorsports
Tuner: Will Brawley @ Raw Performance Tuned
Engine Specs:
82mm CSS block
Skunk2 Alpha Rods
Supertech Pistons
RP Ported Head
Crower 405's
Supertech Valvetrain
BRMS Top Mount
Borg Warner 11 Blade Billet Compressor Wheel S366
VP113
875 HP/ 565 TQ
You Tube
Engine Specs:
82mm CSS block
Skunk2 Alpha Rods
Supertech Pistons
RP Ported Head
Crower 405's
BRMS Top Mount
VP113
875 HP/ 565 TQ
You Tube
#40
I made a best of 497 @ 21 Psi at PFI Speed here in Johnstown,CO. Mind you we only had it at 10 degrees of timing when we did the final pull. I ran a best of 10.9@135 with a 1.77 60'. We had it turned up to 26Psi then the sleeves started to literally fall apart in Cyl 1.
Here is my setup
B18A1
81.5mm 10.9:1 Arias pistons
Golden eagle rods
ARP rod bolts
Stock cast B20 head
Crower 62403 cams
Supertech valve springs/retainers
Revving to 8500
PFab Ramhorn manifold
Precision 6266 JB turbo
Tial MVR 38mm
3" up pipe
LS trans
Mfactory LSD
Stock gearing
Really simple setup and I was able to run a 11.1 right off the trailer with no adjustments. Ran a 10.9 @ 135 a couple runs later before the sleeve gave out. We were probably pretty close to 600HP when the sleeve gave.
Here is my setup
B18A1
Golden eagle rods
ARP rod bolts
Stock cast B20 head
Crower 62403 cams
Revving to 8500
Tial MVR 38mm
3" up pipe
LS trans
Mfactory LSD
Stock gearing
#42
#44
Red Line:
84MM Benson Sleeved B18B1.
-Stock LS crank
-ARP Head studs
-Eagle Rods
-CP Pistons, 9.7:1
-GE 84mm / OEM headgasket
-PR4 head, factory ports
-Crower 62404 N/A cams
-Crower Springs and TI retainers
-Victor X Intake
-Greddy Type RS BOV
-2.5 Mild steel charge piping
-Treadstone TR8 Intercooler
-Five 'oh Motorsports 1400cc Injectors
-Walbro 400 E85 Version
-GoAutoworks T3 Ramhorn
-Tial 38mm Wastegate
-STC Reaper 62mm. Was an SC6152E that was uprgraded with Reaper wheel and Garrett parts
-Full 3" Exhaust
-Tuned on eCtune by myself
-Boost by gear
-1st and 2nd 15lbs,
-3rd 25-27lbs
-4th and 5th 30lbs
-Stock LS crank
-ARP Head studs
-Eagle Rods
-CP Pistons, 9.7:1
-Victor X Intake
-Greddy Type RS BOV
-Full 3" Exhaust
-Boost by gear
-1st and 2nd 15lbs,
-3rd 25-27lbs
-4th and 5th 30lbs
Topdawgg
07-07-2007 10:19 AM
mwasnp
03-21-2003 09:03 AM
