Finally got some base numbers for my 84mm LS/Vtec 35R topmount
Got some base numbers for my 84mm LS/Vtec GT35R- 442whp
After a few days of street tuning and workin out some bugs with the datalogging, I made some base runs on the dyno tonight to see where it sits...
First run was 442 whp 288 tq corrected... Using a Dynojet. Ill post the graph later on
wastegate set to 1 bar, and creeping up to 20 psi slowly up to 8200
made a couple more runs fixing the A/F a tiny bit.. it was a tiny bit lean because my wideband had been reading slightly off compared to the dyno..
Started to rev higher and it was still makin power up to 9000... thats where we stopped...
This is still on PUMP gas, 91 octane, with nothin touched for ignition basically... very mild..
the shitty plugs i was using started crappin out on me, so we stopped, but this was a good start I would say... Not gonna go higher on pump... still gotta make some mid range power, it hasnt been touched at all.
Turbo Setup
Garrett GT3582R (4bolt converted to Vband)
Turbo Elements Top Mount Manifold
Turbo Elements 4 inch Downpipe W/Vband
3 inch Catback Stainless Kteller Exhaust
Tial 44mm Wastegate
Tial 50mm Blow Off Valve
RC 1000CC injectors - waitin on these
Precision 750hp Intercooler
Block
Golden Eagle 84mm Sleeved B18a BLock
CP Pistons 9.0:1 Compression
Pauter Rods
Polished and balanced Crank
ACL Bearings
ARP Main Studs
ARP Head Studs
Head
B16A2 Head
GSR Cams
Supertech Valves
Supertech dual valvesprings
Supertech Titanium Retainers
Port and Polished by Dave Lind (local head shop)
Edlebrock VictorX Intake Manifold
Holley 68mm Throttle body
Fuel Management
AEM Fuel Rail (not on)
Walbro 255 Intank Fuel pump
Aeromotive FPR --waiting on this
Tuned with Crome Pro
GM 3-Bar Map sensor
Innovate LM-1 Wideband
A picture of it before it went in the car, with the old intake manifold
Modified by Topdawgg at 11:16 AM 7/7/2007
Turbo Setup
Tial 44mm Wastegate
Block
Pauter Rods
ACL Bearings
ARP Main Studs
ARP Head Studs
Head
B16A2 Head
GSR Cams
Supertech Valves
Fuel Management
GM 3-Bar Map sensor
Re: Finally got some base numbers for my 84mm LS/Vtec 35R topmount (dturbocivic)
wow, very nice we have almost the same build. Mine is not done yet but I hope to get the same results.
not sure why the 44mm was creeping up to 20 psi... wasnt too impressed.. Im gonna change springs and get the 20 psi throughout the powerband, not just up top
Modified by Topdawgg at 11:49 AM 7/5/2007
Re: Finally got some base numbers for my 84mm LS/Vtec 35R topmount (Topdawgg)
gotta feel good to finally get it on the dyno. congrats topdawg, im sure youve been waiting a long time for this.
that engine is way to sexy for low boost, pump gas, and a single plate clutch! mmmmm pauter rods.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg »</TD></TR><TR><TD CLASS="quote">not sure why the 44mm was creeping up to 20 psi... wasnt too impressed.. Im gonna change springs and get the 20 psi throughout the powerband, not just up top</TD></TR></TABLE>
i feel your pain, 20psi is crazy on pump, 91 at that, i was creeping to 20-21psi on my old manifold, and with my new manifold i got it down to 17.5psi at 9k, i only spin to 8k on pump though. people were telling me i was crazy for wanting to go dual wastegate!
dyno chart, and pics of the car please
Re: Finally got some base numbers for my 84mm LS/Vtec 35R topmount (mike@synapse motorsport)
Once I knew that there was still power to be made up around 9000, i called it a night... and put the rev limit back down to 8000...
no point really...
but we also richened it up, so its even better now.... alittle less power, but its conservative..
no point really...
Re: (Topdawgg)
Modified by Topdawgg at 11:49 AM 7/5/2007</TD></TR></TABLE>
i can tell you why its creeping, but you probably already know......
Re: (R@mon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R@mon »</TD></TR><TR><TD CLASS="quote">
i can tell you why its creeping, but you probably already know......</TD></TR></TABLE>
No he doesnt
No he doesnt
Re: (Boostwerks.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostwerks.com »</TD></TR><TR><TD CLASS="quote">4" DP into a 3" exhaust? Interesting.
Either way...looks great man. </TD></TR></TABLE>
just for daily driving... IDEALLY i wanna just remove the 3 inch for the track and for big numbers.... thats how i set it up
Re: (mike@synapse motorsport)
Creeping from 15psi to 20psi and you wonder why its still making power It just means your turbo isn't blowing hot air yet.
Still 442 on 91oct, gsr cams and nothing too fancy, good numbers for the GT35R. I bet it still has a decent spool time too.
Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">Creeping from 15psi to 20psi and you wonder why its still making power It just means your turbo isn't blowing hot air yet.
Still 442 on 91oct, gsr cams and nothing too fancy, good numbers for the GT35R. I bet it still has a decent spool time too. </TD></TR></TABLE>
yea.. full boost just over 5 grand... which is really not too bad when i plan to rev to 92-9500
Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike@synapse motorsport »</TD></TR><TR><TD CLASS="quote">haha i wish you were on aem, i would love to see the similarities in the tune.</TD></TR></TABLE>
that would be cool
that would be cool
