Who is running the highest mileage on their boosted car?
Re: Who is running the highest mileage on their boosted car? (DB2)
do you mean, how many miles have you been boosting? or how many miles did your car have when you decided to boost? just not sure what you mean.
answer to first-150 miles
answer to second 126,000
Re: Who is running the highest mileage on their boosted car? (fmaxturbochic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmaxturbochic »</TD></TR><TR><TD CLASS="quote">do you mean, how many miles have you been boosting? or how many miles did your car have when you decided to boost? just not sure what you mean.
answer to second 126,000</TD></TR></TABLE>Both would work. Didn't think about that.
Re: Who is running the highest mileage on their boosted car? (KC GSR)
my integra has 188k on it and i have been boost it for 1 year. i boost 10psi daily after tune tune tune my car.
Re: Who is running the highest mileage on their boosted car? (gsrt)
I shouldn't be posting since its not boosting it yet.. but I'll be running boost next year as a test before the rebuild.
By then, I imagine it'll have over 210,XXX.
It's very possible to run moderate boost (12psi) on a high mileage motor without losing <u>seal</u> on the rings or head gasket. Rod & crank bearings will take a beating though. I've done several leak down tests on this motor ever since 163k miles, and it has been the same:
1.54 r/s
#1 - 98.5%
#2 - 98.0%
#3 - 97.5%
#4 - 98.25%
@ 196k miles
Im certain that it'll run just as well as a boosted 2000 mile LS.
Just relieve crankcase pressure, run different oil, and keep it tuned well.
1.54 r/s
#1 - 98.5%
#2 - 98.0%
#3 - 97.5%
#4 - 98.25%
@ 196k miles
1997 GSR
95,000 - JRSC 6psi, 01-2002
137,000 - 10psi, 251WHp, 181 lb-ft, 01-2003
153,000 - still running strong today, loses less than half a quart every 5000 miles...
Damn, I didn't realize some of you guys have as many miles as you do. That's awesome. I would really be worried about seal on the rings mainly, but I guess that isn't an issue here.
Re: (Blue-Civic-Hybrid)
Odometer says 207,000. The motor has maybe 50k? I boosted a while on the single cam. Things haven't been working out too well for me with the b-series lately. Just a matter of figuring out why I'm losing coolant before I get a good tune on it.
started boosting at 120,000 miles on my 95 integar gsr and sold the car with no motor and trans becouse i kept it at 160,000 miles drag kit with 10 psi drove it all over every day
Re: (DB2)
I have had mine for 15000 miles at 15lbs daily driven hard as **** 20lbs on race gas a few times. Its a GSR motor with only Inline Pro Headgasket and Block gaurd on stock motor. Im probably jinxing myself it will probably blow anyday now ...haha
Re: (boostaholic)
just curious what size/trim turbo, and what fuel management.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostaholic »</TD></TR><TR><TD CLASS="quote">i run 24psi through a block with the stock sleeves that have 160k miles on it.</TD></TR></TABLE>
Re: (rioninja)
YAh that seems a bit extreme to me as well. I would like to know too. I know you havent gone 160,000 miles on it you must mean your car says 160000 miles...but how long have u been running that
I rebuilt the block with 154k miles on it, still stock sleeves though so the sleeves themselves have about 160k miles of wear and tear on them. Boosting on it since then, i run 20-24psi w/ a 60-1 and speedpro.
