Ben Strader {EFIGUY} asks for your help
Old Jan 22, 2005 | 11:11 PM
  #26
95c1v1cs1's Avatar
Default Re: Ben Strader {EFIGUY} asks for your help (D-t)
Replied
Thanks Ben for all the Great Information. I own the Book and took the Class!
Corey
Old Jan 23, 2005 | 02:11 AM
  #27
racinskittle's Avatar
Randy Rasmussen
250 Snow Bird Loop
Homewood, CA
Add to Address Book, Map (530) 525-4819
Randy Rasmussen
10152 Silverton Ave
Tujunga, CA
Add to Address Book, Map (626) 446-0358
Randall B Rasmussen
4643 Campton Rd
Eureka, CA
Add to Address Book, Map (707) 444-3744
Randolph Rasmussen
9627 Helen Ave
Sunland, CA
Add to Address Book, Map (818) 352-3828
Randy Rasmussen
10152 Silverton Ave
Tujunga, CA
Map (818) 446-0358
Randy Rasmussen
868 Cottonwood Ct
Lincoln, CA
Map (916) 408-4564
Which is him?
Modified by racinskittle at 11:32 AM 1/23/2005
Old Jan 23, 2005 | 05:18 PM
  #28
EFIGUY's Avatar
Default Re: Ben Strader {EFIGUY} asks for your help (racinskittle)
Thanks again everybody for the great support!
I look forward to many more years of giving to the H-T community.
Old Jan 23, 2005 | 06:21 PM
  #29
.nate's Avatar
Damn Ben... I heard you were writing a book, but had no idea that it was out... I gotta pick this up
Old Jan 24, 2005 | 02:33 PM
  #30
Andre's Avatar
Default Re: Ben Strader {EFIGUY} asks for your help (EFIGUY)
Hello Ben,
i think i've found a mistake in your book. On page 31 you write "A bar of boost, which indicates a manifold pressure of roughly 14.5 psi gauge pressure or 25.2 psi absolute (at sea level)."
The pressure at sea level is 14.7 psi, so a manifold pressure of 14.5 psi would be 29.2 psi absolute.
Next thing is on page 21 it says a injector duty cycle of 85% is the maximum acceptable limit, on page 44 it says you should not push the injectors past 80%.
Can i go on with criticism?
You have used a demo version of the FAST and other software. The reader might think you have just downloaded the software but never worked with it. You should also hide the taskbar, the reader don't cares when you took the screenshot and that you've used Photoshop
Otherwise the book is good but should go more into detail.
Andre
Old Feb 12, 2005 | 02:26 PM
  #31
Andre's Avatar
Default Re: Ben Strader {EFIGUY} asks for your help (Andre)
Hello Ben,
there is more in the book i don't agree with. Let me quote what you have written on page 41:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
A multi-point system is one that fires all of the injectors simultaneously, once every revolution. A multi-point system only requires a signal from the engine sensors to tell it the engine speed.
You have three types of multi-point injection
- simultaneously
- sequential
- batch fire
The reader of your book might think a simultaneously multi-point injection is the only multi-point injection.
Hondas have a multi-point injection too, but a sequential.
The book is very unclear here.
Andre
chiefb26
10
Apr 5, 2008 04:25 PM
Arturbo
Jan 18, 2004 02:24 AM
2k1_ITR_0736
Jan 31, 2003 09:56 AM
