base map question
Old May 23, 2007 | 06:29 AM
slowex98's Avatar
Default base map question
does anyone have or know where I can find a turbo basemap for a d16y8 just something to start off with trying to tune it with crome
Old May 23, 2007 | 07:12 AM
Boostedb20EH2's Avatar
Default Re: base map question (slowex98)
Have you been on pgmfi.org? Im sure there is some helpful info/people on there.
Old May 23, 2007 | 08:24 AM
slowex98's Avatar
Default Re: base map question (Boostedb20EH2)
can't get on that site for some reason
Old May 23, 2007 | 10:21 AM
ralph11sec's Avatar
just go ahead and use the boost tools. its pretty east to make a base map. use 120% efficiency for fuel and .75deg/lb of boost.
Old May 23, 2007 | 10:23 AM
slowex98's Avatar
Default Re: base map question (ralph12sec)
will it be reliable
Old May 24, 2007 | 05:06 AM
slowex98's Avatar
bump
Old May 24, 2007 | 05:32 AM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowex98 &raquo;</TD></TR><TR><TD CLASS="quote">will it be reliable </TD></TR></TABLE>
No, but no basemap is. Too rich or too lean are both bad. So is too retarded and too advanced timing.
Each cause damage in their own way. One more then the other. The reason why basemaps aren't reliable is because not only is each setup different, but simple things like unsynched timing or a bad flowing injector, etc etc are going to effect the tune.
Please just make a little basemap and set boost cut at like 2 PSI. Leave it in closed loop and everything will be fine until you get to a tuner
Old May 26, 2007 | 04:15 AM
malubawla's Avatar
Default Re: base map question (adseguy)
pm xenocron....he does chipping and good basemaps
Old May 28, 2007 | 06:52 PM
ralph11sec's Avatar
Default Re: base map question (malubawla)
basemap is never reliable. learn how to tune. diy it!
Old May 28, 2007 | 08:16 PM
Topdawgg's Avatar
yea, if you understand how it all works, a basemap is really simple...
you are still kinda flying blind if you dont have a wideband to check the a/f
TinyTitan
Sep 7, 2007 06:42 PM
DrivinVtec
Jan 25, 2007 06:33 PM
.::Lee::.
Jun 7, 2005 07:33 PM
xsnrgsr
Jul 31, 2003 06:38 AM
JRSCCivic98
Jun 20, 2002 07:36 AM
