BASE MAP needed. Help with Ideas. Thanks. (UBERDATA)
Old Apr 24, 2004 | 11:56 PM
AspectIndustries's Avatar
Default BASE MAP needed. Help with Ideas. Thanks. (UBERDATA)
My Specs are.. (in sig also)
GSR b18c1 + p72 ECU w/OBD1 Harness (Sportin UBER!)
Turbonetics t3t04e 57/63
SSauto Tubular Manifold (5 Bar Braced)
Tial 38mm .5 Wastegate
Greddy Type S BOV
Greddy Turbo Timer - Faze Gauges w/indash pod
3" Magnaflow, Resonator & Downpipe
Custom FMIC 25x7x3*2 1/2" inlet/outlet
Custom FMIC 2 1/2" pipings
440dsm Injectors
B&M Fuel Regulator
Pushing 7lbs of Boost. For now... Can someone give me an outline on what I should do for a map.. ( I know Dyno/Street Tune is a must, but I want something to run safe, for 7lbs of boost for now )
I know Uberdata Forum shows how to make a basemap, but how about a basemap to run my Turbo setup.
AIM: viet2lonely
Any help I can get, is appreciated.. Thanks..
Old Apr 25, 2004 | 07:24 AM
Mad Cow's Avatar
Default Re: BASE MAP needed. Help with Ideas. Thanks. (synik)
The "How to make a basemap" thread on the uberdata forum is exactly what you need. That *is* for your turbo setup.
Old Apr 25, 2004 | 08:51 AM
blackeg's Avatar
Default Re: BASE MAP needed. Help with Ideas. Thanks. (MadCow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCow &raquo;</TD></TR><TR><TD CLASS="quote">The "How to make a basemap" thread on the uberdata forum is exactly what you need. That *is* for your turbo setup.</TD></TR></TABLE>
madcow has it right. follow those steps and make a basemap, then get your hands on a wideband(or on a dyno). grab your a/f ratio and make changes accordingly to get it to 12:1 or so. &lt;- basic idea. also read keebler's how to tune uberdata post on the uberdata forum. look around on http://www.boosted-hybrid.com, there is alot of good info there on how to go about tuning. also read this http://www.importbuilders.com/tuning.html. hope this helps and good luck with the tuning
edit: i just saw that you plan on logging a/f in the future. either way, read over some of what i linked you to, its got good info that wont hurt to know
Old Apr 25, 2004 | 09:08 AM
Joseph Davis's Avatar
Default Re: BASE MAP needed. Help with Ideas. Thanks. (blackeg)
Since you have a GSR engine, I recommend a stock GSR program as your basemap. Just modify it with Uberdata as needed for your setup
91b18a1ls
Engine Management and Tuning
27
Oct 14, 2014 02:23 PM
shabam
Jun 6, 2009 09:57 AM
ef9_b16a1
Dec 11, 2007 03:54 PM
Beau Gotti
Feb 3, 2005 11:52 AM
AspectIndustries
Jul 11, 2004 06:54 AM
