Bad Idle after turbo install
I recently just installed my turbo kit and i started up the car to see if the car ran fine and it does not. The revs bounce up and down. I have hondata with datalogger, rc 550s, basic kit, stock fuel pressure. Could the car be that badly tuned that it will not run right or could it be a vacuum leak from the wastegate or BOV?
Re: Bad Idle after turbo install (NewportSI)
i have the map sensor t-ed off for the blow off valve could that be the reason? I checked all the vacuum lines and they seem fine.
Re: Bad Idle after turbo install (GWInquisitor14)
okay i just started it up agian, pulled the spark plug and its filled w/ gas. Its gotta be running very rich.
Re: (Wojo97civic)
hopefully that will do the trick. Im thinking its running so rich that the spark plugs are fowling out. Because i was told the idle is so bad, that a vacuum leak couldn't make it that bad.
edit: I remembered that when i first started it up, it ran fine just really dark n smokey. I shut it off then turned it on about 1 min later and it ran bad.
Key Enzyme
Engine Management and Tuning
03-29-2013 08:24 AM
96f22b2
11-06-2011 12:04 PM
descartesfool
05-22-2008 02:38 AM
