backpressure
Old Aug 31, 2007 | 09:17 AM
anton_'s Avatar
Default backpressure
how much back pressure do you guys have?
i thought mine was a little high, iam only boosting 14psi
my setup is
b16a1
Garrett 57trim stage 3 turbine 63 A/R
UGR manifold 3"downpipe and exhaust with no cat
itr cams
the light blue line is rpm
the pink is boost
yellow is back pressure
max backpressure was 1,4 bar
[IMG][/IMG]
Old Aug 31, 2007 | 09:21 AM
tony413's Avatar
you probably shoud have went with a .80 or better A/R. anyways are you sure you arent building a crap load of crankcase pressure
Old Aug 31, 2007 | 09:54 AM
anton_'s Avatar
Default Re: (tony413)
i have a catchcan with 2, 12an from the block and the headcover has a filter on it.
why do you ask that?
Old Aug 31, 2007 | 10:10 AM
tony413's Avatar
Default Re: (anton_)
ok just checking have you tried setting the catch can up from the back side of the block ?
also whats the turbo specs and how much you reving it too
Old Aug 31, 2007 | 11:15 AM
anton_'s Avatar
yes its from the back of the block and i am reving 8800 but i shift gear when i reach 8500.
the turbo is a garret t04e/t3 57 trim
stage 3 turbine wheel 63A/R on the turbine and 60 on the compressor
Old Aug 31, 2007 | 11:25 AM
alpha's Avatar
Default Re: backpressure (anton_)
Where are you monitoring backpressure?
Old Aug 31, 2007 | 11:27 AM
anton_'s Avatar
Default Re: backpressure (alpha)
i took it one Inch from the collektor
Old Aug 31, 2007 | 11:53 AM
mrbsponge's Avatar
what kind of power is the car making? where does it peak? and where does it fall off?
these answers would determine if backpressure would even be of concern.
Old Aug 31, 2007 | 12:33 PM
TiAL's Avatar
Default Re: backpressure (mrbsponge)
we had one guy running 29psi of boost and had 75psi backpressure LOL
he was wondering why the wastegates were opening on their own.
Old Aug 31, 2007 | 12:43 PM
anton_'s Avatar
Default Re: backpressure (TiAL)
haven't dynoed yet but i have checked my hp with a gtech and a AP22 and it sas that the peak hp is around 8200-8500. the car pulls hard all the way to readline
Old Aug 31, 2007 | 01:36 PM
HiProfile's Avatar
That would be a 1.55:1 ratio - thats not high at all. Most oem setups go well past 2:1, while VERY few 4-cyl turbo setups go below 1:1. You will tell when your exhaust/turbine becomes a big restriction - torque will drop like it was a V8 at redline.
Old Aug 31, 2007 | 04:20 PM
anton_'s Avatar
Default Re: backpressure (HiProfile)
but the b16 with itr cam should be very sensitive to backpressure because of the high value cams. a friend of mine drive a s40 t4 with 442 hk and 30psi and the backpressure don't pass the intake pressure
he has one of these turbos, made in Sweden but the price is 2100$
http://www.turboservice.se/KX500.html
its a kkk27 but with some other pieces
b18sihatch
Oct 15, 2006 10:33 AM
Spooled1.6L
Apr 11, 2004 11:53 AM
DimSum321
Mar 14, 2003 12:20 AM
88CRXHybrid
Jan 4, 2002 06:23 PM
