b20vtec t70 boost cut
Old Jan 30, 2010 | 04:32 PM
eli92188's Avatar
Default b20vtec t70 boost cut
i have a b20vtec in an ek chassie and iam hittin boost cut at 8psi dunoo why.....iam usiing a stock p06 chippt with type r maps...i thought a honda ecu would b fine till 10psi bfor the map senser sees boost...oo and i have the missin link on all it did is make the limp mode go on at a later rpm...???
Old Jan 30, 2010 | 05:09 PM
eli92188's Avatar
Default Re: b20vtec t70 boost cut
dose anyone know where i can chip my ecu for like an 4 bar omni map senser
Old Jan 30, 2010 | 07:45 PM
boostedcivicsir's Avatar
Mr. Badwrench
ok im lost, a stock po6 with type r maps?
boost cut with a missing link?
how can the ecu see boost and know to cut boost if the ecm cant see positive pressure?
according to your post, you have a mess or a disaster waiting to happen.
is the po6 setup for boost? if it is ditch the missing link and have it tuned properly. while chips get you close, you can only get the car right is if you tune it.
18gLUDE
Jan 13, 2008 04:14 PM
Horseofcourse
Aug 3, 2007 12:15 PM
Qveon
May 5, 2006 10:28 AM
rice is nice
Dec 18, 2004 02:21 PM
evil_elmo
Dec 4, 2001 12:10 PM
