B20B4 turbo
Old Sep 21, 2010 | 12:09 PM
tundra2000's Avatar
Default B20B4 turbo
So i got an 1994 civic hatch with a B20B4 turbo in it and i was wondering what the estimate hp on it when its running 10 psi and tuned at 15 psi ( he turn the boost down for normal driving) and this is my first turbo civic so i would like to know so maintenance things i should do to keep it running good and how long would it last running 15 psi for some normal driving and some racing?
And why is it when i shift then push the gas pedal all the way it will feel like it died or something for like a second then it takes off, why does it do that?
not sure if the motor is stock, i will ask tomorrow. And I have an wideband o2 sensor and it stays in the rich until i let off the gas then it goes lean.
Old Sep 21, 2010 | 12:11 PM
D Griff's Avatar
Default Re: B20B4 turbo
Is the motor stock or built for turbo? Do you know any of what's in it?
Old Sep 21, 2010 | 12:15 PM
ekphil's Avatar
15psi on a b20 is pushing the limit of the cylinder walls but if you have a good tuner you may be able to get away with it as for how long it will last i dont know. This is assuming that you have a stock block. If your car came tuned you may want to get a wideband o2 sensor just to make sure that it is a good tune plus over time your car will come out of tune so its always nice to have.
94Eg_SnatchBack
Oct 25, 2011 12:41 PM
CivCruise
Jun 25, 2009 09:49 AM
Drake_ep3
Sep 5, 2008 07:29 PM
superman336
Jan 31, 2007 10:34 AM
GapxGuy
Jan 11, 2007 12:15 PM
