B20 turbo = problems
Old Feb 14, 2006 | 10:29 AM
jfruauff's Avatar
Default B20 turbo = problems
Ok me an my boy just put a turbo in his car heres the setup.
B20 bottom stock
B16 head with some work nothing major
T28 turbo
ok the problem is when anymore than 17% throttle is giving car sputters bad. It is only on 6 psi and has plenty of fuel. Car still pulls but the noise is crazy. Sounds like compressor surge maybe spark blowout but 100% louder. Tried to switching header gasket, different injectors. I have tried everything. Turbo is good took it off other car. Had a little problem with the oil exit line on turbo backing yup but fixed right away.. Any ideas...
Old Feb 14, 2006 | 10:33 AM
turbosnatch's Avatar
sounds like a tuning problem, what is he doing for fuel mgmt
Old Feb 14, 2006 | 10:41 AM
urbansi's Avatar
Default Re: (turbosnatch)
Well i have like 20 questions
Well when you are talking about compressor surge do you mean while in boost or out of boost, because if its while under boost its a wastegate problem.
Does the sputter only happen while under boost?
What kinda of injectors are you running? high impedence/low/saturated/peak & hold???
What is the fuel management
What is the timing look like
Any idea on what AFR's the car is putting out
What kinda plugs are you using/what gap
Sputtering sometimes leads to map related problems.
Is ther any CEL's coming on
Old Feb 14, 2006 | 10:53 AM
jfruauff's Avatar
Default Re: (urbansi)
It happens even just when you rev it but louder when driving.
It only does it when throttle is applied it he puts the peddle down slowly it wont do it.
I am not really sur the independance but the are I think 450s.
Timing has not been adjusted just set 0,0
Not sure on air fuel but sure it is rich
I do think he needs colder plugs and to lower gap the are ngk v powers and gap is .40. But sound to loud for spark blowout.
Its a hondata computer.
Like I said whole setup was taken out of another car that ran fine with 13psi we installed and set to 6psi till we could get and air fuel ratio to tune. Car is running at around 55 psi on fuel with the 440 or 450 injectors..
I really am lost thanks for the help guys
Old Feb 14, 2006 | 11:04 AM
nonvtecD's Avatar
you need fuel management
Old Feb 14, 2006 | 11:06 AM
jfruauff's Avatar
Default Re: (nonvtecD)
so why did it run fine in the other car but bad at this one. He has a VAFC2 in this car but I dont think its been adjusted.
Old Feb 14, 2006 | 11:09 AM
nonvtecD's Avatar
the AFC hack is not proper management especially when not tuned correctly
Old Feb 14, 2006 | 11:15 AM
jfruauff's Avatar
Ok but can you explain why it ran fine on the other car then we swap everything computer, wiring harness ( it has a resistor for the injectors), turbo mani setup, ect over and with 7 psi less boost it makes this flutter??? Yes i understand the fuel management .
Old Feb 14, 2006 | 11:24 AM
Si Shane's Avatar
Default Re: (jfsrt4)
no one can explain you are right.
Old Feb 14, 2006 | 11:29 AM
jfruauff's Avatar
Default Re: (Si Shane)
Man I am serious. Dont start that crap. I am new to honda I drive a SRT4 with all kinds of mods and tunes of performance and general car experience. Its my buddies car and I am helping him we are just confused on why we swapped everything and its not right.. If you dont have any helpful comment please post crap somewhere else.
Old Feb 14, 2006 | 11:43 AM
all go teg's Avatar
so wait,<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfsrt4 &raquo;</TD></TR><TR><TD CLASS="quote">
was this the management system on the turbo set up in the first car when it was tuned at 13 psi? if so it will be running very rich, and that would cause the car to sputter. and about the noise you are hearing i am not sure.
Old Feb 14, 2006 | 11:49 AM
jfruauff's Avatar
Default Re: (all go teg)
yes everything was swapped from the other car. Ill try pulling some fuel and seeing if it helps..
Old Feb 14, 2006 | 12:52 PM
nonvtecD's Avatar
If the car you swapped it from wasn't the exact same motor it probably is going to run like crap, exactly how it is, it needs to be tuned like I said.
Old Feb 14, 2006 | 12:53 PM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfsrt4 &raquo;</TD></TR><TR><TD CLASS="quote">Its a hondata computer.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">you need fuel management</TD></TR></TABLE>
take it to a tuner...it will be money well spent.
Old Feb 14, 2006 | 12:55 PM
tallyturbo's Avatar
that gap seems big to me. i hame mine set at around .30
ludelvr
Sep 6, 2009 05:44 PM
turboteg86
Feb 10, 2007 01:49 PM
tl
Jul 6, 2004 11:30 PM
Ef-er
Jul 1, 2004 02:46 PM
TrumpTiteJoker
Mar 25, 2004 05:26 PM
