B20 boost?
Old Aug 24, 2006 | 07:44 PM
Subterraneous's Avatar
Default B20 boost?
Hi everyone. This morning i picked up a 1990 CRX DX with a blown motor.
I was thinking of possible motor swaps, and a B20b came up. Id imagine the motor is pretty good for turbo, low compression, high displacement, etc... Plus, the longblock can be had for 6-700 bucks.
How much boost can a stock motor take? Im gonna rebuild whatever motor i get before i drop it in, just for piece of mind.
I did a search, but there was no "B20" in all of the forced induction forum.
Thanks!
Old Aug 24, 2006 | 08:28 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: B20 boost? (Subterraneous)
the sleeve designs suck. they crack way to easily. just get an ls, and if you want more displacement slleeve it and bore it out
Old Aug 24, 2006 | 08:30 PM
Default Re: B20 boost? (wantboost)
how much boost can they take?
Im on a budget, and i jsut want to piece together a kit to get mabye 200whp.
Old Aug 24, 2006 | 08:39 PM
Tuesday Club's Avatar
I'm actually in the process of B20z supercharged......As long as you keep the pressure LOW, you will be fine. It will be a fun/peppy build, but not v8 killin'.
Old Aug 24, 2006 | 08:41 PM
Default Re: B20 boost? (Tuesday Club)
how low is LOW? like 7 psi?
Dmc1's Avatar
Honestly B20's have weak sleeves but usaully any motor can take 10 psi.
Just make sure to get it tuned by a really good tuner timing is going to be critical.
Blundar
Joseph Davis
Jeff Evans
You need a tuner on their level. Then the B20 should run fine.
I see so many b20's in the junkyards around here I'm kind of tempted to grab one and try it out.
Old Aug 26, 2006 | 11:41 AM
jaredcrx91's Avatar
building a b20/gsr head myself, have turbo intercooler whole set up, ill let you know in a couple weeks how its runnin
Old Aug 26, 2006 | 02:00 PM
Hondoctors's Avatar
We have a EG with a stock B20 block and head. Putting 10 lbs boost on a Hondata S300 and 550cc injectors. Put down 230 whp and 220 ft.lbs, runs 12.4 at 108 mph. Been running for almost 2 years now.
Old Aug 26, 2006 | 02:14 PM
boostedb20teg's Avatar
Default Re: (Hondoctors)
i'm also on a b20b turbo i just sent the block to be sleeved 2 days ago i already have my fully built head and pistons rod but still shopping for the right turbo and i'm going to try motec or micro tech ecu's
Old Aug 26, 2006 | 03:28 PM
spoolin turbo s's Avatar
Default Re: (boostedb20teg)
here is a b20 with stock sleaves oh yeah with a vtec head
Car: Integra
Engine: B20vtec, stock sleeves, 84.5mm, 9:1 comp, skunk2 valvetrain, CTR cams, GE cam gears, skunk2 IM, skunk2 70mm tb
Mods: Log manifold, t3/t4oe 60 trim .63a/r, 2.5" dp, 3" exhaust, custom 2.5" charge pipes, blitz bov, tial 38mm gate, dumptube, turbo xs dual stage boost controller, RC 550cc injectors, walbro 255lph hp pump, neptune
Tuning at 9psi and 13psi on 93 octane:
Old Aug 26, 2006 | 04:54 PM
jaredcrx91's Avatar
what tranny would be better for b20/turbo? and what engine managment are you guys using?
Old Aug 26, 2006 | 07:29 PM
mrbsponge's Avatar
one of the biggest pitfalls is not only its sleeves but its lack of the "standard" honda PCV system. ALL of the B20s pressure comes thru the head.
you need to set it up properly on the back of the block, the spots are there, they just arent used
slideintegra08
Aug 6, 2021 07:30 PM
:::SIRll_EJ1:::
Sep 1, 2009 05:50 AM
juanchoenuncrx
Mar 16, 2008 10:17 AM
4thgenx42
16
Oct 11, 2006 02:54 PM
B20-T
Jun 19, 2002 04:11 PM
