Will a B18B gearbox..........
Old Sep 24, 2002 | 06:38 PM
Endles's Avatar
Default Will a B18B gearbox..........
Will a B18B gearbox bolt onto a B18C block???
Are the B18B gearboxes as strong as a Y21 gearbox?
what is the strongest hydralic gearbox for B series honda engines?
and finaly... are there aftermarket LSD's available for the B18B box?
sorry bout all the q's but im strugling to find info on the above
Old Sep 24, 2002 | 06:51 PM
Kamin's Avatar
Default Re: Will a B18B gearbox.......... (Endles)
you mean will an LS transmission go onto a gsr block?
yes
all b series transmissions are interchangable.
all the honda trannys are weak, none are stronger than another
not that i know of, http://www.quaifeamerica.com dosent list one
Old Sep 24, 2002 | 09:04 PM
Kataku2K3's Avatar
Default Re: Will a B18B gearbox.......... (ridge racer 2)
Yea you are gonna take forever to rev up with that tranny.. It's for B18B's or crazy *** turbo motors that will spool up forever. I wouldn't do it.
Old Sep 24, 2002 | 09:07 PM
Kamin's Avatar
weak? these transmissions are used on 800+hp cars with only upgraded axles. Personally I would'nt try that but even 400+ is easily done.
1) if its a STOCK honda transmission it only lasts a couple runs before it needs a rebuild (ask jinxproof and his former 10 second hatch) you cant put that much power through a transmission.
2) you can have a custom one made thats totally bulletproof but there 4000$+-
Old Sep 24, 2002 | 10:56 PM
B18C-EJ1
Guest
Posts: n/a
They are all about the same in strength.
Why you want to buy a LS tranny with LSD in it?
If so, PM me.
Old Sep 25, 2002 | 02:21 AM
Endles's Avatar
Default Re: Will a B18B gearbox.......... (B18C-EJ1)
Well ive got a B18C with garret T04E turbo
last dyno read 438hp @ 18psi
But im needing a new tranny
Most important that I can put an aftermarket LSD in it
I have access to 100% NEW unused gearboxes
Old Sep 25, 2002 | 06:44 AM
CheezeFrog's Avatar
Default Re: Will a B18B gearbox.......... (KAMiN)
BS, no Honda can run 10's!
Old Sep 25, 2002 | 09:43 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Will a B18B gearbox.......... (CheezeFrog)
Are you REALLY that stupid?
Old Sep 25, 2002 | 10:26 AM
carl_aka_carlos's Avatar
are you for real??
Old Sep 25, 2002 | 10:36 AM
UTI tunin's Avatar
your joking right?
Old Sep 25, 2002 | 11:31 AM
Kamin's Avatar
1) if its a STOCK honda transmission it only lasts a couple runs before it needs a rebuild (ask jinxproof and his former 10 second hatch) you cant put that much power through a transmission.BS, no Honda can run 10's!
ok
if you say so
you must be smarter than everyone else on this board.
Old Sep 25, 2002 | 12:21 PM
CheezeFrog's Avatar
That's funny. You guys act all surprised when I say no Honda can run 10's. But nobody bats an eye when Kamin says that stock Honda trannies need a rebuild every two runs. Both claims are pure BS. I'm thinkin one of two things here. 1) Nobody here has any experience with a fast Honda. Or 2) Kamin was just joking. Hahah good one, K!
Old Sep 25, 2002 | 12:24 PM
CheezeFrog's Avatar
Run my Civic and I'll show you just how "st00pid" I really am
Old Sep 25, 2002 | 02:24 PM
B18C-EJ1
Guest
Posts: n/a
What does your civic and any Honda running 10's have to do with this?
No honda can run 10's huh????
I submit the following all motor HONDA CIVIC
[Modified by B18C-EJ1, 3:26 PM 9/25/2002]
Old Sep 25, 2002 | 04:49 PM
lazy bum shaughn's Avatar
Ok, come on guys, dont you think he was messing around?
I certainly hope so, because I would like to see what he posted the last 800+ times!
Old Sep 26, 2002 | 12:08 AM
Endles's Avatar
Please keep on topic
anyway, the Quaife dealer tells me that he can get one for a GSI (New Zealand model Integra with a B18B) and also tells me that all the insides of the boxes are interchangeable.
is he full of BS?
Old Sep 26, 2002 | 01:54 AM
B18C-EJ1
Guest
Posts: n/a
You know you can use the LSD from a cable Y1 tranny. Same FD, and all that is necessary is a bit of machine work on the inside case.
A used Y1 LSD is about $400-500, machine work and assembly is about $200-300.
So for what you would pay for a Quaife, you could have a OEM installed.
The OEM Y1 LSD is a gear drive as well.
Old Sep 26, 2002 | 04:57 AM
CheezeFrog's Avatar
My LS tranny (Quaife LSD is the only mod) has seen many many 450+hp passes with absolutely no problems. So I'm not sure where Kamin got the idea that a tranny has to be rebuilt every two passes.
B18C-EJ1 that's a BS photoshop dude. I still don't believe you that a Honda can run 10's. Even 12's. OMG get real!
Old Sep 26, 2002 | 09:20 AM
B18C-EJ1
Guest
Posts: n/a
Hopefully you're kidding, and just ******* with everyone here, because if you're not, you've got issues, and need to stop living in that cave of yours.
Old Sep 26, 2002 | 02:18 PM
Endles's Avatar
Sounds good
From what ive found out the B18B (LS, Y80) tranny has smaller syncros than the Y21 etc, but has the 4.266 final drive and more turbo friendly gear ratios (slightly better gearing) and you can get a Quaife LSD and probably a Kaaz LSD too?
Now what I need to know is about this Pro Drive stuff?
Where can I find out about it on the internet?
Old Sep 27, 2002 | 06:54 PM
Kamin's Avatar
see that picture?
now sit down
you have been 0WN3D
Syphon
Jul 26, 2003 02:08 AM
BorderM3
Feb 12, 2003 01:46 PM
