b17 turbo
Old Aug 1, 2011 | 04:19 PM
ChRiS_p123's Avatar
Default b17 turbo
hey guys,
i have a b17 with b16 head, motor is preety well stock. crank and rods are b17, pistons b16, car ran good but not enough power. over the winter i had decided to boost it and long story short before i could even get it tuned i found bearing in the oil pan . so i am in the need of a rebuild. so i figure why rebuild with stock parts?
looking to make around 350hp on mild boost 10psi-14 psi, heres what i am thinking of doing.
- stock bore block maybe 81.5-82mm depending how the cylinders look.
- GE block guard (dont really want to sleeve and probably not necessary for my power goals)
-crower rods
-cp pistons
-stock crank
-b16 head ported and polished
-skunk 2 IM
-chipped ecu
-looking at skunk 2 cams may just use gsr
-new valve springs and retainers not sure which brand. suggestions?
-innovate wideband
-hks ssqv bov
-turbo is a greddy tdo5h-18g
-ebay intercooler and piping
-new oil pump, bearings, gaskets
do you think this set-up will reach my power goal?
any comment or suggestions much appreciated.
any changes you would make? i have looked for some info in b17 builds and seems they are few and far between.
thanks in advance
00CivicSi5spd
Jan 9, 2018 06:48 AM
Silvertc
Oct 14, 2010 03:32 PM
Bwhit12
Sep 21, 2009 01:08 PM
highrevnef
May 17, 2005 11:15 AM
