b16t setup holland
hey guys i wanna now what you think of my new setup
and what you will change or not
b16 84mm darton mid leeved
cp pistons 9.0:1
eagle rods
arp head studs
acl bearings
balanced crack flywheel and poulie
weight all the rods and pistons
all the bolts and everythink on the block is new oem honda
b18 highflow oil pomp
l19 arp rod bolts
eagle head gasket
skunk 2 pro valve train
skunk 2 pro retainers
b18c cams
skunk 2 cam gears
edelbrock victor x intake
70 mm throttle body
bdl fuel rail
1600 cc pricision injectors
bwr ramhorn
44 mm tial wastegate
garrett gt35r
act clutch
lsd gearbox
3 inch piping whit tial 50 mm bov
3 inch bumper exit exhaust
big xs power fimc
bosch 044 fuel pomp
car is going to run on e85 hope to go in 600hp
this is the setup for now im running for now itr cams
because money is a issue
cp pistons 9.0:1
eagle rods
arp head studs
acl bearings
l19 arp rod bolts
eagle head gasket
b18c cams
skunk 2 cam gears
70 mm throttle body
bdl fuel rail
bwr ramhorn
garrett gt35r
act clutch
lsd gearbox
big xs power fimc
bosch 044 fuel pomp
You're doing just fine until the "big XS Power FMIC" and the "BWR" manifold.
You might have some difficulty getting 600hp (to the wheels) on those Delphi 1600cc injectors. (Precision gets them from Delphi) on E85. More than likely a BOSCH series 2000cc injector would be in order.
Boostedb20EH2
Jul 25, 2008 08:43 AM
MBlake55
Mar 24, 2008 01:15 PM
