g23 good 4 turbo?
Old 01-17-2009, 01:10 PM
skillzhb's Avatar
Default g23 good 4 turbo?
hey guys i wonna no if the g23 build is good 4 a turbo cuz iam buildin it and i wonna turbo just need more info
Old 01-17-2009, 01:14 PM
Man U FTW
Schister66's Avatar
Default Re: g23 good 4 turbo?
Any engine can be turboed but how much power you can make is a different story. I'm not very familiar with the G23 (i know its an H and F frankenstein) so i can't really give you much. What are your goals and is the engine internally stock??
PS: Writing more clearly so that we can understand you would be great
Old 01-17-2009, 01:20 PM
skillzhb's Avatar
i mightt just turbo it stock 4 now but if i have more money iam gonna build it fully i wonna no if it good stock with a turbo i dont want it 2 bolw on me
Old 01-17-2009, 06:01 PM
Moderator
TheShodan's Avatar
WHAT!!!
C'mon man. take the time to write a good question so it can benefit all.
Old 01-17-2009, 11:44 PM
HiProfile's Avatar
I've seen built motors blow up because the owner cheaped out on tuning - nothing is bullet-proof, so to speak. If you boost the stock setup, you could probably get 200-300whp out of it with a good tuner pulling the strings, assuming you don't redline it every gearchange. The good thing about the G23 is the cheapness of the F22 block and its iron sleeves (as you must know of the FRM crap). The downside I could see are the cast pistons, and the possibly sketchy compression. You'd want to keep it below 9.5:1 for (relatively) low boost, 9:1 for moderate boost - I don't know what a G23 works out to.
btw dog, try 2 spl ot da entr wrds. dis aint no cel phn scrn y0
Old 01-29-2009, 02:45 PM
kingofbattle909's Avatar
you need to change the pistons or the rods.
i bought a f23 block my brother was using for his g23 build and the valves came in contact w/ the pistons. (partspartsparts)
Old 02-01-2009, 10:18 AM
jdm99ek's Avatar
i may be wrong, but if you do a G23 build a want to turbo it, keep the f23 pistons, should give a 8.8:1 CR, rather than 11.5:1 w/ the K20a2 pistons.
blue2000em1
07-09-2007 08:56 PM
QUICKERSILV3R
01-04-2004 07:14 PM
GTRVspecII
11-18-2002 10:58 PM
4gvtec
09-19-2002 07:08 AM
Quick Reply: g23 good 4 turbo?
