B16A2 Turbo Sizing Question
Old Aug 23, 2009 | 02:20 PM
chemkid86's Avatar
New User
Default B16A2 Turbo Sizing Question
So I have been researching the crap out my build and I am still putting together pieces here and there.
I was thinking of running a GT3076R Turbo with a 0.63 AR but I was looking at the compressor maps and think it might not work out for my car. Should I run the smaller GT3071R because my engine is a little closer to the efficiency islands on that map, or is the 3076R going to make more power while still remaining close to the 3071R's low end spool up. Compressor map links below...
I guess I am just worried about the turbo surging before it even hits the efficiency islands...
Looking to run 10psi and make anywhere between 300hp - 400hp
A few details of the build:
B16A2 9.0 CR, Portflow Headwork, Crower Stage 2 Turbo Cams
Full Race Turbo kit
AEM Fuel Setup with 550cc injectors
hondata s300 dyno tuned
so on and so forth
Many more bells and whistles so if you need any more information on the setup, just let me know.
Looking to do this right so trying to get as much info as possible. Thanks in advance!
Here's some info to help you read the compressor maps...
Creator: Jacob Fannon aka Def
ENGINE PARAMETERS
Liters 1.6
VE 90
Press Ratio 1.8 11.6 psi
AIRFLOW CHART
RPM 2000 3000 4000 5000 6000 7000 7500 8000 8500 9000 9500 10000
CFM 92 137 183 229 275 321 343 366 389 412 435 458
LB/MIN 6.42 9.63 12.84 16.05 19.26 22.46 24.07 25.67 27.28 28.88 30.49 32.09
Old Aug 23, 2009 | 03:03 PM
Ls_dx's Avatar
Default Re: B16A2 Turbo Sizing Question
I am really happy with my 3076r .63 on my b16
Old Aug 24, 2009 | 05:06 PM
blinx9900's Avatar
I didn't see how much power your after but i too LOVE my GT3076R on my 1.6, i previously had a t3/t04e ball bearing and have driven MANY different boosted Honda's i must say i love mine.
The setup:
-b16b head
-b16a block with pr4 pistons a .050" head gasket
-3" turbo back
-custom GT3076r turbo kit with a ramhorn mani
-91 octane 8.3 compression 333whp at 12psi.
P00ni
May 9, 2014 05:16 AM
chemkid86
Aug 23, 2009 02:43 PM
eddie5141981
Aug 8, 2008 02:45 PM
90Rexx
Oct 10, 2006 06:18 PM
nota-eg
Oct 12, 2005 11:10 AM
