B16a Turbo Setups
Old Jun 16, 2012 | 10:52 PM
  #1226
St0ckEg's Avatar
Default Re: B16a Turbo Setups
Here is my set up.
b16 block std bore
9-1 wiseco piston
Eagle rods
Off brand bearings lol
Gsr head
Type b blox cams
Golden eagle cam gears
Blox dual valve springs and retainers
1600cc Bosch injectors with eBay fuel rail.
Victor x intake manifold with 68mm blox tb
Dual Bosch 044s -8 feed -6 return
On e85
top mount manifold
Master power t70 turbo
46mm eBay wastegate
4in down pipe. Well out the hood
Tilton twin disk clutch
Gsr tranny welded diff
3.9dss axles. That's about it.
1.6 making 630@27-28 lbs of boost
Best time 10.14@144
Old Jun 19, 2012 | 01:25 AM
  #1227
vtec_turbo10's Avatar
b16a stock sleeves
81.5 9.1 srp pistons
eagle rods
std head gasket
std head bolts need arp tho
b16a 2 head
kelford cams
rev springs
rev retainers
std valves
eagle style intake
70mm tb
after market fuel rail
550 injectors
500 hp intake fuel pump
turbo set up
ramhorn manifold
turbosmart gate
turbosmart bov
masterpower t70 turbo
3" exhaust from down pipe right through
racepro frount mount
hondata s300 ecu
350 hp easy
Old Jul 7, 2012 | 08:16 PM
  #1228
DELshaneSOL's Avatar
b16a jdm bone stock
just with apr head studs
walbro 255 fuel pump
440 rc injectors
ramhorn mani peakboost
3inch open dp
turbonectics turbo,bov and wastegate
50trim t3/t4
s4c tranny
stage 3 comp clutch
lightweight steel flywheel from comp
dyno tuned
no o2 sensor turned off
tuned on .6 bar about 8.5 psi
made 293 whp
and 199 tq
Old Jul 8, 2012 | 01:18 AM
  #1229
rich7777's Avatar
Spec on this page... https://honda-tech.com/forums/showth...997100&page=14
Follow on for results...
Old Jul 9, 2012 | 02:42 PM
  #1230
rico892002's Avatar
Originally Posted by St0ckEg
Here is my set up.
b16 block std bore
9-1 wiseco piston
Eagle rods
Gsr head
Type b blox cams
On e85
top mount manifold
46mm eBay wastegate
Best time 10.14@144
what part of TX u located?
Old Jul 25, 2012 | 07:40 AM
  #1231
Xathine's Avatar
B16A3 bottom end
Nippion replacement pistons
Stock rods
ACL bearings
ARP rod bolts and main studs
Crank polish
Cylinder hone
Rods reshaped
Still deciding on what head work to do. Currently just have a completely stock b16 head. Will probably upgrade the single valve springs to dual valve springs from a GSR.
Only shooting for sub 300whp for a DD.
Old Jul 25, 2012 | 07:47 AM
  #1232
BigZeke5's Avatar
Upgrade the valves, valves springs and retainers. Get GSR cams. If you can find type R cams, even better. The block would nice if you had forged rods and pistons. Just sayin...
Old Jul 25, 2012 | 12:20 PM
  #1233
Xathine's Avatar
Only looking for 300whp. Forged internals seemed over kill.
I'll probably upgrade to b18 dual valve springs, possibly cams after boost.
Not sure on valves though. Any info on why I should?
Old Jul 25, 2012 | 12:39 PM
  #1234
BigZeke5's Avatar
I dont thinks its over kill. Its more like a little security knowing that the block will hold the boost even though it can handle the boost. I guess I'm speaking more of the future than anything else cuz once you feel that turbo kicking in, your gonna want more power! I know from expierince lol!!!
Old Jul 25, 2012 | 03:42 PM
  #1235
ls joker's Avatar
Loved
Hell yea.... another turbo honda from ohio.
Youll be good on a completely stock b16. I made 285whp/188wtq mustang dyno, back when i had a stock motor.
Once your ready for more boost, you obvisously need to build your internals. Boost causes as much stress on the valvetrain as it does on the block. When you do build your valvetrain, get steel retainers. Cams arent a must necessarily.
Hell i made 364 mustang dyno on b16 cams at 18psi. At that point i new i needed bigger cams. After upping the boost and not getting any gains kinda screams whats needs to happen
Old Aug 7, 2012 | 01:19 PM
  #1236
VolkswagenWHO!!!'s Avatar
Just went through all 50 pages of this thread and there are some bad *** set ups in here. In for some more stock motor set ups, so keep em comin! Hoping for a 10 sec pass out of a CRX, stock B16, Garrett 57 trim. Ill post once its done.
Old Aug 7, 2012 | 01:25 PM
  #1237
BigZeke5's Avatar
Your gonna need 400 to 430 hp to hit tens. I have 404 hp at 20 pounds of boost with a garrett 57 trim. and my best time is 11.2 It can be done though. If I'm nit mistaken, CRX is lighter than an civic dx hatch?
Old Aug 7, 2012 | 02:35 PM
  #1238
St0ckEg's Avatar
I stay in Arlington
Old Aug 7, 2012 | 03:44 PM
  #1239
The car should weigh around 2000lbs with me in it. Do you know what your car weighs with you in it? Even if I get a 10.99 ill be happy with that.
Old Aug 8, 2012 | 06:49 AM
  #1240
BigZeke5's Avatar
92 civic dx hatch model with the 1.5l engine weighs 2190. I have a b16a2 in it and me at 160 pounds, I say the car weighs 2450 pounds. I'm adding 100 pounds of motor to that total...
If your weighs under 2,000 with you in it. With 400 HP you will hit tens, if you know how to drive. For every 100 pounds is a tenth.
What transmission you using?
Old Aug 8, 2012 | 09:03 AM
  #1241
b16racereg6's Avatar
I got a 57trim on my stock b16, 8psi street tuned i love it dude. I do not have a High HP car but its soo much fun and i love stock mustangs lolol.
Old Aug 8, 2012 | 06:38 PM
  #1242
Im gonna start with a cable b16 just so I can get the car done and out on the track. Eventually I plan to convert to hydro and run a gsr.
Idk man with your car weighing 2450lbs race weight and 400hp hitting 11.2, I think at 2000lbs with like 380ish, some slicks, and good suspension will do the job along with some good driving from myself of course. We will see though.
Old Aug 8, 2012 | 06:46 PM
  #1243
Damn your not even in the 300's as far as horsepower goes. Go get a dyno tune and crank that boost up. You think its fun now, go make like 300-350 and you'll smile ear to ear lol.
Idk why ppl seem so weird about crossing the 300hp mark with stock B16's. That's what it seems like from what ive seen in this thread.
Old Aug 9, 2012 | 05:19 AM
  #1244
BigZeke5's Avatar
Thats coo. I feel you there. But converting to hydro GSR is definately the way to go. I use an lsd gsr trans and in my opinion its perfect for turbo cars! I have good slicks MH 24.5X8.5X13 on lenso, good suspension (tein) as well....
Old Aug 9, 2012 | 05:29 AM
  #1245
BigZeke5's Avatar
Most likely its a daily driver and its the first time boosting. I remember when my first tune was at 264 hp, then went to 327hp and now currently at 404hp. And I plan on going higher lol!!!
Old Oct 31, 2012 | 11:01 AM
  #1246
BigZeke5's Avatar
A little update on my B16a2 turbo. Just took it to the track this past Friday and ran a personal best of 11.1 Didn't make any power changes. Just made changes to how I launched off the hole (no two stepping) and worked very well.
Three years of daily driving, winter driving, driving to the track, race at the track, drive it back from the track, and this year alone I made over 20 passes and still running strong. I am a happy dude that walks all over just about anything in the streets lol....
Anybody else got b16a2 turbos thats still running.....?
Old Oct 31, 2012 | 01:53 PM
  #1247
Steeve_Civic's Avatar
What will be the total cost for a 250WHP from a Stock B16?
Thank you
Old Oct 31, 2012 | 01:59 PM
  #1248
BigZeke5's Avatar
That question is really a vague question.....
Old Oct 31, 2012 | 02:04 PM
  #1249
SiRCiviC94's Avatar
just give a vague figure like 3000$
in the spring I am looking to tune the b16a bone stock it sits abouts 250whp im shooting for about 325 or less depending how my tuner feels. it will require a bigger map sensor though I dont think 11lb will cut it..
still on an ebay 57trim dyno tuned on chrome 680cc injector walbro255 etc
Old Oct 31, 2012 | 02:09 PM
  #1250
BigZeke5's Avatar
If your using a 57 ebay trim then your right, the stock map sensor wont do it.
