B16a Turbo Setups
Old Sep 24, 2011 | 02:43 PM
  #1076
utahturbosohc's Avatar
Default Re: B16a Turbo Setups
100% stock b16a. bosch 1000cc inj. Garrett t3/t4 57trim. precision 600hp fmic. tial 38mm WG. greddy bov. drag cast mani. cc stage4 clutch and fly wheel. dss 3.9 axles. gsr trans, liberty handcuff, spool. aem boost solenoid. sunoco 116 fuel. Tuned on Neptune by Cortney Green. final #'s were at 22psi.
This is a car i built for my little brother.
Old Sep 25, 2011 | 08:15 AM
  #1077
Turpid Porpoise's Avatar
Very good numbers, that 57 trim puts up some pretty impressive numbers on b16s
Old Sep 25, 2011 | 03:04 PM
  #1078
Lol Thanks. My jackass brother 1-2-1 shifted and killed that motor right after making his best pass, 11.7@121.
Old Sep 25, 2011 | 03:17 PM
  #1079
Old Oct 2, 2011 | 08:34 PM
  #1080
BoostedEgHatchFl's Avatar
Hows the spool up of the 6262
Originally Posted by Trojan Man
6262 is fun.
I won't post a chart with A/F readings but I'll post my normal graph.(this one wasn't the last pull, but like 7whp/2wtq off)
Old Oct 9, 2011 | 01:30 PM
  #1081
^ Ill let you know in a few months when I get my built and sleeved top mount 6262 finished and tuned.
Old Oct 10, 2011 | 02:48 AM
  #1082
be18see1's Avatar
Just tuned yesterday to, honestly, pretty dissappointing numbers.
Setup:
Darton sleeved stock bore B16A block
Eagle rods
9:1 CP pistons
Stock head
GSR cams set at 0,0
Victor X
69 mm throttle body
1000cc Rochester injectors
Precision SC6169 (.63 AR exh, .70 comp)
Payn mini-ram
3" downpipe
open exhaust with turn down
2.5 charge piping
huge eBay intercooler (~30 x 18 x 3)
best run was 290 whp/194 tq @ 18 psi with a blown throttle body gasket that we didn't notice. Basically at 7500, the curve levelled out and stopped making power. If you follow the curve, I should be around ~350 whp.
Old Oct 10, 2011 | 03:48 AM
  #1083
i would be disappointed with those numbers as well. But I would imagine that blown throttle body gasket would create a huge boost leak.
Old Oct 10, 2011 | 06:53 AM
  #1084
be18see1's Avatar
I sure hope that's what it was. I guess it was actually 17 psi and my datalogs show 17 psi so I don't know. Not sure exactly what the problem is. I'm going to install my Profec spec II and maybe look for some cams+valvetrain and see what I can do with that.
Old Oct 10, 2011 | 07:45 AM
  #1085
b16racereg6's Avatar
Fix that leak and strap it back on and go from there dude.
  #1086
Your sensors may be reading 17 psi but your turbo is spinning faster to produce that psi because of the boost leak creating a serious reduction in efficiency.
I think cams and valvetrain will help your peak number quite a bit but sealing up any/all boost leaks will really improve your numbers by making your turbo run at peak efficiency. If you need any help you can pm me and Ill do what I can to help you out.
Old Oct 10, 2011 | 08:11 AM
  #1087
be18see1's Avatar
This makes sense. I didn't think about it like that. I've helicoiled the intake manifold threads that were stripped, cut and installed a new gasket, and run it around a bit. It's definitely running better but it sure takes a long time to spool which I definitely don't like. I'm thinking opening up those valves a bit more, poooossibly stepping my cold side charge piping to 2.25, and rerouting my hot side piping through the frame rail instead of up and over will help (93 Integra).
Old Oct 10, 2011 | 09:15 AM
  #1088
Trojan Man's Avatar
No Sales Forums
From: Reading the Chronicles and Blowin Trees in Virginia
Or I'll let you know now...
It's a bit laggy. Once it gets going though, it's hard to stop. Its good though, acts like a stock all motor car until 5500ish and then its all hell from there on out.
Old Oct 10, 2011 | 09:21 AM
  #1089
BigZeke5's Avatar
Setup:
Eagle rods
9:1 CP pistons
Stock head
GSR cams set at 0,0
Victor X
69 mm throttle body
Payn mini-ram
3" downpipe
2.5 charge piping
Whoever tuned your car failed to do a boost leak check. Had he done that, he would have found the leak and got if fixed before it got put on the dyno and make the pulls for nothing..... Sounds like you got more leaks than just that throttle gasket. Do a boost leak check, find your leaks, get it fixed, and come back with 350-400 hp numbers!
Old Oct 10, 2011 | 11:00 AM
  #1090
be18see1's Avatar
It actually had two bolts that were stripped and the throttle body became loose. I have no idea where else it could leak from.
Old Oct 10, 2011 | 11:03 AM
  #1091
Are you using worm gear clamps or t bolt clamps on your charge piping? And your charge piping is fine for you setup there is no reason to step up. If your using worm gear clamps I highly recommend switching to some nice t bolt clamps to help with boost leaks.
With that being said, if your throttle body was as loose as you say it was then that could possibly account for the 100hp you could be missing? Don't know if you mentioned it but what kind of dyno were you on?
Old Oct 10, 2011 | 11:16 AM
  #1092
BigZeke5's Avatar
Where else? Intercooler, intercooler piping, inter cooler couplings, wastegate and/or blowoff valve, crack in the exhaust manifold, crack on the intake manifold you might not see. Do a boost leak check and make sure you have no leaks before you take it to dyno. You want effiency out of that turbo. Like the previous person said, yeah your readings show 17-18 but the turbo is pushing more psi's. No need to make the turbo push more air than what it needs to.....
Old Oct 10, 2011 | 11:20 AM
  #1093
BigZeke is 100% correct, basically anything on the outside of the main engine assembly(i.e. block/head) can be a potential boost leak. You can even get a leak from old/damaged injector o-rings and spark plugs.
Old Oct 10, 2011 | 11:31 AM
  #1094
BigZeke5's Avatar
If you have an o-ring injector leak, can you say possible fire lol!
Old Oct 10, 2011 | 11:40 AM
  #1095
Haha yes you can, I actually had a very minor boost leak that accounted for about .25 psi from my injector o-rings on my previous SRT-4
Old Oct 16, 2011 | 07:18 PM
  #1096
mikesrex's Avatar
here is my b16 turbo setup: https://honda-tech.com/forums/forced-induction-16/my-1-6-stock-bottom-end-turbo-integra-build-2986320/
it's basically a stock B16A motor but with GSR pistons and cams, ITR intake, blox log manifold with a t3/60-1 running 14 lbs on 93 octane pump gas maxing out denso 720's
went 11.9@117 in my 2650lb 96 integra (full interior with me driving)
Old Oct 16, 2011 | 08:17 PM
  #1097
Not to mention, if it has been tuned with a boost leak, and you fix that boost leak, now all your boost comp stuff will be off... bye-bye engine :/
Start the car, and put a piece of sheet metal, or something similar that cant be sucked into the turbo, over the inlet of the turbo, and see if it dies. If it stays running, start searching for boost leaks. Brake clean or carb clean come in handy. Spray it around. you'll know if there is a leak.
Old Oct 17, 2011 | 02:39 AM
  #1098
I recommend soapy water, you don't wanna suck in brake cleaner.
Old Oct 17, 2011 | 03:32 AM
  #1099
be18see1's Avatar
I'll give you guys an update when I have some spare time. Thanks!
Old Oct 17, 2011 | 04:16 AM
  #1100
^^ good idea never thought about that befor...
