B16a Turbo Setups
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxhfb16 »</TD></TR><TR><TD CLASS="quote">its no where near running lean. its running way to rich right now. I got about 150 miles on the last tank of gas.</TD></TR></TABLE>
You have run it back to back on the dyno with a a/f? Tell me it doesn't run lean after the second pull. Unless your running 4psi it's lean.
b16a2 stock
rx7 s4 turbo , rb20det ehxaust housin
2-2.5"-3" piping
external wastey
stupidly large fridge
450cc
gotta get it tuned up.. not my car.
http://img393.imageshack.us/im...g.jpg
last car, ef9t..
b16a1
hiflowed t3 duno with what
1.75' piping :s
basemap obd0 turboedit
5psi
external
13.7 @ 167 on 175/65/14
been 2 years and still goes.
2-2.5"-3" piping
external wastey
450cc
last car, ef9t..
b16a1
1.75' piping :s
5psi
external
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1598cc »</TD></TR><TR><TD CLASS="quote">
13.7 @ 167 on 175/65/14</TD></TR></TABLE>
Tell me that's km/h not mph
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">everybody here runs on stock trannys?
also.... what clutch does the +300hp guys have?</TD></TR></TABLE>
Type R tranny (LSD) with a RPS Max series clutch.
How long do those clutchs last for?? My buddy has a clutchmasters stage 5 4puck unsprung and was told it will only last 10-15k miles.
I have a stage 3 ACT in mine. Will this be ok for the torque i will be making at upper 300whp to lower 400whp. If not what should i switch to.
My XTR6 went for a year on my daily driver making over 400 WHP with lots of drag racing, and I slip it a lot when I launch. I replaced the disk because I had the tranny out anyway, but it was still working fine.
The pedal feels fine, it's a bit stiffer than stock, but not bad. I'm 39 with bad knees and it doesn't bother me. The 6-puck doesn't chatter anywhere near as bad as a 4-puck or 3-puck, it took me a day or two until I could drive it without any shaking. My wife takes the car to work on the weekends, it only took her a couple of days to get used to it, and she normally drives a Ford Taurus with an automatic. The great thing about it is that you can slip the hell out of it without burning it up. I slip it like crazy on drag launches to spare my axles.
*update* just bought crower rods and arias pistons for my motor, gotta upgrade my IC and then im gonna shoot for 500+hp on stock sleeves, head and intake manifold.
Wish me luck
ill keep you guys updated.
Wish me luck
* USDM b16a2, stock
* Rev Hard Iron/Tubular Manifold
* Precision SC34 .60/.63 a/r
* Rev Hard 2.5" downpipe
* Tial 35mm ( 7lb spring )
* Spearco 30x8x3.5 intercooler
* 2.0" intercooler piping
* HKS SSQ Bov
* Hondata S200 Engine Management ( Base Map, no tuning, ever. )
* Walbro 255lph in-tank pump
* RC 440cc Injectors
* GReddy 2.5" Cat-back
* ACT 6-puck Clutch w/Heavy Duty PP
Dyno @ 9psi 240whp / 167wtq
I put ~35,000 miles on this motor with no hints of problems.
With 220whp/150wtq I ran 13.4@104 w/2.2 on DR's
20+whp & 20+wtq more? Who knows?
* HKS SSQ Bov
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanAutry »</TD></TR><TR><TD CLASS="quote">
* USDM b16a2, stock
* HKS SSQ Bov
Dyno @ 9psi 240whp / 167wtq</TD></TR></TABLE>
That setup is very efficient compared to the Greddy 18G setup.
Your torque is much lower than mine which could mean that it breathes easier than my setup. I am getting 189.8 wtq @ 11 psi hitting 232whp. This is with greddy DP, stock exhasut size pipes and magnaflow Cat.
* USDM b16a2, stock
* HKS SSQ Bov
I will as well try and keep this bumped...
Heres my setup in the making:
Completly stock B16 bottom end.
GSR head with .5mm over supertech valves, PNP, RM dual springs.
(10.8 compression).
GSR cams
Blox turbo manifold
BB .63ar T3/T4 60 trim
2.5" DP with wastegate actuated cutout.
3" custom exhaust
Neptune
550cc RCs
Walbro 255HP
JG intake mani
Newer street imports IC (same core as spearco).
B16 cable tranny with a Quaife.
Full-Race traction bars
D2 coilovers
The goal for this motor is for 300 uncorrected WHP. Because I'm at 5600ft, it is going to be making close to 400 corrected...
I am looking for a high to mid 11, on 24.5" slicks.
(10.8 compression).
GSR cams
Blox turbo manifold
3" custom exhaust
Neptune
550cc RCs
Walbro 255HP
JG intake mani
D2 coilovers
