B16a Turbo Setups
last year's setup I made 311 hp on a dynojet and ran a best of 11.23 at 123 mph at Woodburn. boost was 15 psi.
gsr cams
supertech springs/retainers
stock valves
stock im/tb
wiseco 9:1
crower econo rods
rev hard cast mani
garrett t3/t4e 60 trim .63 exhaust
2.5" exhaust
2.5" ic piping
tial bov and wastegate
ectune
this year i'm hoping for 400 hp with the following changes
sc6262sp turbo
ramhorn mani
3" exhaust
skunk2 im and 68mm tb
neptune ems
this is in a 1g crx
gsr cams
stock valves
stock im/tb
wiseco 9:1
crower econo rods
rev hard cast mani
2.5" exhaust
2.5" ic piping
ectune
sc6262sp turbo
ramhorn mani
3" exhaust
neptune ems
this is in a 1g crx
Hey...
Here`s my Little B16 project...
Not finnished yet..
Spec:
B16A Longblock.. stock sleeves for now..
Goal is 600whp+ on racegas... (Vp or Sunoco)
500-550 on pumpgas... (98-99 Octane over here..)
- B16A Head
- Port&Polished By In-Tec Motorsport, Stage 3 (in-tec.no)
- SuperTech valves
- Supertech Valveguides
- Supertech Valvesprings
- Supertech Titanium Retainers
- Supertech Valve seals
- AC Autotechnic Drag manifold (polished)
- RPM 70mm Throttlebody
- NGK 9s
- ATI Racedamper
- FJO Injectordriver
- GE Rods w/ 3/8" ARP 2000
- CP Pistons (81.50mm)
- Custom Camshafts, Made to In-Tec Motorsport specs.
- 1200cc injectors
- MSD Digital 6 ignition Unit
- MSD SS Coil
- MSD cap
- GM 3Bar MapSensor
- AEM adjustable cam gears
- AEM lightweight pulley (Dist.)
- AEM Fuel Rail
- AEM Wideband o2 (UEGO)
- Aeromotive A1000 Fuelpump
- Aeromotive Fuel Pump Controller
- Aeromotive Fuel Filters
- Aeromotive Fuelpressure regulator
- T1 Race Development Oil Catch tank
- Apex`i AVC-R Boost Controller
- Autometer EGT w/ Probe
- Hondata Heatshield Gasket
- Full Race B Series ProAm T3/44 Turbo Manifold, Polished!
- Full Race 4" Downpipe (3"up to 4" ) (sent off to Polish!)
- DIY Dump Tube Kit , 1.75" pipes w/ V-band
- Garrett T04Z-R Turbo (Anti-Surge, Polished and Chromed!)
- Tial Wastegate 44mm (Purple)
- Tial 50mm Blow Off Valve (purple)
- Adel Wiggins Flexible Tube Connectors 3" (x5)
- Vibrant Performance Intercooler 12"x26"x3"
- Vibrant Performance Custom 3" I/C piping
- Vibrant Performance Vaccum manifold
- Vibrant Performance Timing Belt tensioner
- Thermal R&D 3" Turbo Exhaust
- Hondata S300b
- ObD2B Socketed P28
- Nology hotwires
- Fluidyne aluminum radiator
- Twin 8" Fans (thight space when using 4" Dp)
- Custom Fan-rack/mounts
- Greddy radiator mesh hose
- JDM red honda valve cover
- Thermal flex hoses
- Aluminium Radiator resevoir tank (polished)
- Brake fluid tank cap (polished)
- Earls Oilcoolers, 2x 13 Row coolers
- Earls Steel Braided Hoses & Fittings
- Earls Steel braided hoses- fuel line
- Earls THermostat
- Earls Sandwich adapter
- Earls Oil Return Line hose and fittings (Turbo)
- Earls Fuel Lines -10an & -6an
- HASPORT Engine mounts
- RCI 10gal. Fuelcell
- PERFORMANCE CLUTCH Twin Plate (version "B")
Not finnished yet..
Spec:
- B16A Head
- SuperTech valves
- NGK 9s
- ATI Racedamper
- 1200cc injectors
- MSD SS Coil
- MSD cap
- GM 3Bar MapSensor
- AEM Fuel Rail
- Hondata S300b
- Nology hotwires
- Earls THermostat
What sort of hp are people seeing with stock sleeves before they crack? If you are running 84mm sleeves would it not be better to use a b18, I only ask these questions as I am about to buy a honda motor to fit the fron tof my renault.
probably not. Renegade Raceway is 10 minutes from me, so I race there mostly and opening day is March 27th.. 4 1/2 hours to Woodburn, but I am going to try to make a couple.
oooooo....a floating engine. You're missing a driver mount. You've got some nice stuff man.
Cool little project.
I've seen that design before on a valve cover. I can't wait to get back into boost.
right on man. I hope to see you at boti this year then. car is very clean! Im hoping to finally get some good times out of my setup this year.
99 civic si, stock oem engine + head studs valve springs gsr cams-
full race s400sx kit, motec, t1, tial, exedy twin
spring pressure
***old setup***
blue line stock, orange is performer x.
on the old setup
spring pressure
***old setup***
on the old setup
can some 1 please mail me to help me.I wanna turbo my civic but i need to know the costs involved.theres waay too much info on the net.I know il need forged pistons but i dont understand about rods and the bore sizes etc etc.
i want around 300bhp (max) but with reliabilty, im not fussed about the turbo kits but its the engine build thats putting me off.
theres so many options but turbos the 1 that has the best bhp gains but reliability is a major concern for me.i cant be asked with a motor that doesnt run right.
i figure do it right from the beginning but theres soo much damn things available.
the engine build alone...what would it cost?...forged/uprated bottom end...im asusming the head can be left stock for upto 300bhp?
lol i have been searching.some guys have built bottom ends that go bang with less bhp than guys w stock internals and more bhp.
i spend alot of my time reading up on things.but like i said,peoples opinions some times get mixed in with facts and its too easy to get confused.im going to go with a turbo set up and hopefully my stock internals will do me fine for around 260-280 bhp and as a daily driver.
im gonna either go for a greddy kit, edelbrock if i save up abit more money..or maybe a custom with 1 parts from spoolin performance..i like some of there stuff....im thinkin get a cheap ebay turbo kit, and buy a package deal for the turbo itself and manifold? and use the rest of the parts from the cheap ebay kit?
