B16a torque specs... anyone have a manual handy?
About to put my motor back together.
Can someone post me the torque specs for:
rod bolts=?
head bolts=?
Preferibly in ft/lbs, thats all my crappy wrench reads
Thanks!
rod bolts=?
head bolts=?
Thanks!
Re: B16a torque specs... anyone have a manual handy? (RioNinja)
B16A:
Rod bolts - 30 lb/ft
Head bolts - 61 lb/ft
Tighten the head bolts from the center out in an 'X' pattern. Do this in two steps: First step at 25 lb/ft then again at 61 lb/ft.
These are for stock bolts and rods... If you are using different rods or ARP studs, you need to use different specs.
Good luck
[Modified by B20C5 Turbo, 9:19 PM 5/11/2002]
Good luck
SrT4u2nV
07-19-2006 04:33 PM
H22coupe
04-30-2004 05:24 PM
