B16A with GTX3071R in CRX
I have a 88 crx with a b16a in it and I have a gtx3071r that I would like to put on it. I know I would need to get better rods and pistons, was thinking to go 9.5 - 10 to 1 cr, with a full race or goautoworks manifold and downpipe. Either s300 or Neptune for tuning and was wondering what else I might need (cams, valves, springs, injectors). The car will be driven on the street every day and at the dragstrip often. What kind of power could I expect to get with 92 octane gas and this turbo. Thanks in advance for any help or suggestions
Re: B16A with GTX3071R in CRX
with stock head, cams, inlet and throttle, you can reach about 500hp at 25-30psi. At this power no need for valves, valve springs, etc.
for more power with the GTX3071, you will need cams (I prefer the skunk2 pro1 or the crower 63401T-2), valve springs, better valves, serius porting, inlet manifold, larger throttle, sleeved block, and higher CR at 11:1. (rev limit at 10000rpm)
with all the above mabe you will see about 100 hp more.
for even more power a GTX3076 is required
Who is Mr Robot?
He won't make 500hp on 92 octane...
with a 1.6l motor the chemical limit for 92-93 octane is around 420-430hp
want more than that, use methanol injection.
want even more? you need more displacement or e85/race gas
Who is Mr Robot?
But you're in California, the carb ***** won't like what you're doing. you're sure to get pulled over, sent to a ref, and fined.
Who is Mr Robot?
You don't need sleeves for a pump gas turbo motor. you won't make enough power to need them. you can make 500hp all day long on stock sleeves with a good tune. he's going to do well to make 450hp on 92, more like 400-425 which stock sleeves will handle with no issues
406Honda
08-23-2010 12:25 PM
